Author Topic: Head Markings for 69 Z28 OIl Pan and Timing cover  (Read 5140 times)
muscle joe
  • 1969 Camaro Z28 Butternut 1966 Chevelle L78
« on: April 15, 2011, 01:09:38 PM »
Anyone know what the correct head markings are for a 69 Z oil pan bolt and timing cover   Joe ???
muscle joe
Re: Head Markings for 69 Z28 OIl Pan and Timing cover
« Reply #1 on: April 15, 2011, 09:46:15 PM »
anybody, some one should have this info somewhere
« Reply #2 on: April 15, 2011, 10:26:15 PM »
Joe, there were many different bolt suppliers for GM.  Each supplier had it's own head marking.
« Reply #3 on: April 15, 2011, 11:19:09 PM »
Paul is correct of course (Hi Paul), but to help a little we have two different suppliers on our 68 which include one supplier with the letters "R W B' evenly spaced around the inside edge of hex head and one that has two circles with what looks like a E L4 inside those two ciricles. Kind of wierd as the 4 looks like it is boxed in the L so maybe its something else but it is unique when you see one. I believe you can obtain proper marking bolts from different supply houses like Paragon, etc.
muscle joe
« Reply #4 on: April 16, 2011, 01:15:24 PM »
Ok Thanks, looks like anything will go  Joe
