Author Topic: POP DECODE HELP  (Read 21569 times)
IZRSSS
  • Guest
POP DECODE HELP
« on: April 11, 2011, 06:22:10 PM »
Help Decoding another POP:
T1216JG   124379L514214        R
69G331    BR1001G                      1
               11331                         Bow Tie
Thanks guys!
« Last Edit: April 11, 2011, 07:07:15 PM by IZRSSS »
Re: POP DECODE HELP
« Reply #1 on: April 11, 2011, 06:34:21 PM »
T1216JG   124379L5124214        R
69G331    BR1001G                      1
               11331                         Bow Tie
Thanks guys!
There are too many digits in the VIN, Marty...   ???
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #2 on: April 11, 2011, 06:38:45 PM »
Don't think so Paul. Here's a pic (posted after you post)... There aren't too many numbers...12437= 8 cylinder Coupes... 9=1969...L= Los Angeles (Van Nuys) California... 514214=Sequential Body Number... need help with the rest...
« Last Edit: April 11, 2011, 07:07:50 PM by IZRSSS »
Gramps69Z
  • 69 X33 D80
Re: POP DECODE HELP
« Reply #3 on: April 11, 2011, 07:02:00 PM »
124379L5124214 is the VIN and has to many digits
5124214=Sequential Body Number??
 http://www.camaros.org/numbers.shtml#POPCodes
Captain John Wykoff
HOT3O2
Re: POP DECODE HELP
« Reply #4 on: April 11, 2011, 07:08:35 PM »
The POP said 514214. You added an extra "2".
Rick
69 RS/Z28
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #5 on: April 11, 2011, 07:08:45 PM »
Okay...try this...124379L514214...Thanks guys
Re: POP DECODE HELP
« Reply #6 on: April 11, 2011, 07:13:17 PM »
124379L514214
T1216JG - RPO L35 396/325 with a Turbo 400 assembled on December 16th, 1968 at the Tonawanda, NY engine plant
124379L514214 - VIN
R - Rochester Q-jet carb
69G331 - Turbo 400 transmission assembled on the 331st day of 1968 (Thursday, November 26th, 1968)
BR1001G - 3.07 Posi 12 bolt axle assembled on October 1st, 1968 at the Detroit gear and axle plant (1st shift)
1 - January 1969 build
11331 - Options installed by Fisher Body
1 - N40 Power Steering
1 - J50 Power Brakes
3 - Radio
3 - J52 Front disc brakes
1 - C60 Air Conditioning
You can get more info HERE
« Last Edit: April 11, 2011, 08:01:43 PM by bertfam »
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #7 on: April 11, 2011, 07:20:23 PM »
Thanks Ed! Dang your quick...!
Re: POP DECODE HELP
« Reply #8 on: April 11, 2011, 07:24:10 PM »
What's interesting is the transmission code (G) is for a 396/265 from a full size passenger car with a 2.29 axle! The Camaro L35 Turbo 400 code is a C. However, since they also built the full size cars at Van Nuys, this is probably your typical "not paying attention" POP mistake.
Kurt's going to want to add this to the database, so can you let us know who the selling dealer was?
« Last Edit: April 11, 2011, 08:27:39 PM by bertfam »
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #9 on: April 11, 2011, 07:27:53 PM »
Ed...I meet this guy at the SW Muscle Car Nationals and I said I would give him a hand decoding this. If you can...please shed more light on this G=396/265 & the 400 code E. The guy says its a 396/325HP  ???
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #10 on: April 11, 2011, 07:39:23 PM »
What's interesting is the transmission code (G) is for a 396/265 from a full size passenger car! The Camaro L34 Turbo 400 code is an E. However, since they also built the full size cars at Van Nuys, this is probably your typical "not paying attention" POP mistake.
Here ya go Ed/Kurt...
Re: POP DECODE HELP
« Reply #11 on: April 11, 2011, 08:24:56 PM »
Thanks, and yes, it's an L35 (396/325), not an L34. I mis-typed! But remember, I am NEVER wrong! (Once I thought I was but I was mistaken.)
 ;D
The transmssion codes for the Turbo 400 were used to indicate what model car it was installed in. C would be a Turbo 400 installed in a 69 Chevelle or Camaro with an L35 engine. G is for a full size car with a 396/265 (and a 2.29:1 axle). There were others as well:
A - 396/325 or 396/265 in a full size passenger car
B - 427/390 in a full size passenger car
C - as above
D - 350/250 or 327/235 in a full size passenger car
E - 396/350 in a Chevelle, Nova or Camaro
etc...
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #12 on: April 11, 2011, 08:42:33 PM »
Nice to know we're all human...thanks again Ed...Much appreciated!!!
Re: POP DECODE HELP
« Reply #13 on: April 11, 2011, 08:48:08 PM »
Marty, do you know the guys name? We should add that to the database as well.
IZRSSS
  • Guest
Re: POP DECODE HELP
« Reply #14 on: April 11, 2011, 08:56:17 PM »
Ed...PM sent...
