Author Topic: Build sheet above gas tank, how to remove & other general info.  (Read 8243 times)
rtcat
    • My Camaro's history at Camaro.net
First off, great site!!!  I've learned a lot in the few days I've been reading through the posts.  Thanks to all who support and provide usefull info.
I understand there is a bulid sheet above the gas tank.  Can this build sheet be obtained without removeing the tank?  Can I tell if its there without moving the tank?  What can I learn from this build sheet?
David
1969 Garnet Red base camaro, V8, vinyl top, 4sp. Restoration in progress
gro51
  • 68 SS/RS 350
Re: Build sheet above gas tank, how to remove & other general info.
« Reply #1 on: May 26, 2006, 05:03:36 PM »
Your build sheet MIGHT be above the gas tank.  It MIGHT also be tucked into a seat spring, up under the dash, behind a door panel or even somewhere else.   If it is above the gas tank you may or may not see it.    I sincerely hope you find it but don't count on it.  They're usually long gone by now.  If you do find it it is very useful because it lists every option on the car and other info.   Good Luck.  Keep us posted.
Joe
Schodack, NY
'68 SS/RS 350, M21, 3:73, Rallye Green, Black Deluxe Interior
« Reply #2 on: May 27, 2006, 07:00:26 PM »
Possibly, if your car is an LA car......
