Author Topic: 69 Z/28 spark plug wire looms  (Read 15265 times)
69z28302
« on: March 31, 2011, 12:37:47 AM »
Can anyone tell me which plug wire looms go on what side correctly? A picture would be great.
Thanks CRG
Gramps69Z
  • 69 X33 D80
Re: 69 Z/28 spark plug wire looms
« Reply #1 on: March 31, 2011, 04:28:11 AM »
Is this what you're looking for?  Scan down and look at John's car.
http://www.camaros.org/forum/index.php?topic=7088.0
Captain John Wykoff
Jerry@CHP
« Reply #2 on: March 31, 2011, 05:14:59 PM »
Original left side wire looms have a "two step" bend in them for Camaro.  Many others look the same but do not have the two bends as John's does.  Good photo.
Jerry
69z28302
« Reply #3 on: March 31, 2011, 09:33:27 PM »
Im sorry. I was looking for the part that fit under the valve cover bolts.
Thanks Guy's
flyingskibiker
« Reply #4 on: April 01, 2011, 01:46:15 AM »
Great pictures in Jerry's book...
« Reply #5 on: April 01, 2011, 02:33:31 PM »
<<Im sorry. I was looking for the part that fit under the valve cover bolts.>>
See photos below; note the temp sender wire on the LH side between the two plug wires for #1 and #3.
69z28302
« Reply #6 on: April 01, 2011, 09:26:09 PM »
Thanks as always John Z.
Dave69x33
« Reply #7 on: April 02, 2011, 02:27:21 AM »
Here are a couple more close up pictures.
69z28302
« Reply #8 on: April 02, 2011, 01:15:00 PM »
Thanks Dave and all. That clears up some of my next question. I was wondering where the wire holders on the left of my picture go?
Dave's picture shows the one over the 1 and 3 cylinder. I assume the other goes on the 2468 side? The 2 newer one's are incorrect at the bottom. I need to return them and get the correct kit. I just need to know the placement of them.
Thanks all at CRG
Dave69x33
« Reply #9 on: April 18, 2011, 12:42:54 AM »
69z28302.
My picture does not clearly show the back wire loom, but the loom with the 90 deg bend fits on the rear LH side, over the #5 & #7 cylinders.
The two simple flat looms you show on the upper RH side of your picture appear correct and are both located on the RH side of the engine.
john302
« Reply #10 on: April 18, 2011, 01:00:31 AM »
The right hand picture of the z the heatriser is not installed correctly.It should be turned one stud. anyone else notice that? thanks John    the weight goes to highest position to work correctly
« Reply #11 on: April 18, 2011, 04:48:15 PM »
It's oriented exactly as shown in the Assembly Manual (UPC 6, sheet C6) and on page 13 in Jerry's book.
69z28302
« Reply #12 on: April 20, 2011, 12:42:55 AM »
Thanks Dave. That answers my question.
MM
sdkar
« Reply #13 on: April 21, 2011, 10:47:28 PM »
I see in the Z/28 photos that the driver side wire loom is orange.  Is this the correct color or is satin black?  I have a 69 Pace Car with SS350 and mine is black.  It is the double bent one as shown in the photo here.  Also, mine has the brake booster line going through the large hole in the bracket...is this correct?  Finally, I see on the Z/28 there is a separate bracket for its brake vacuum hose.  Is this correct for Z/28 only?  What is correct for the SS350?
IZRSSS
  • Guest
« Reply #14 on: April 22, 2011, 12:47:21 AM »
I believe these are the correct AIM's for the brake booster line & brake vacuum hose...hope you can make them out.
