Author Topic: 1968 L/89  (Read 8101 times)
OLD IRON
1968 L/89
« on: March 22, 2011, 08:06:20 AM »
Does anyone know what month the first L/89's were made?
Re: 1968 L/89
« Reply #1 on: March 22, 2011, 07:39:00 PM »
I've seen nothing that indicated they weren't available at the start of production.
Jerry@CHP
Re: 1968 L/89
« Reply #2 on: March 22, 2011, 07:54:59 PM »
They were available at the beginning of 1968 production.  As a matter of fact, find the May 1968 issue of Super Street Cars.  They did an awesome article on one of the first '68 L89's to arrive in the NY area.  Has the early bumble bee SS stripe meaning it was built Sept-Dec 1967.  Deliever to Oak Hill Chevrolet, Eastchester, NY.
One of the best articles out there with many photos.
Jerry
OLD IRON
Re: 1968 L/89
« Reply #3 on: March 23, 2011, 06:39:45 AM »
Thanks for the info' Kurt & Jerry.
Were the L/89's assembled at both plants?
Joe.
1968 Z28
Re: 1968 L/89
« Reply #4 on: March 23, 2011, 01:29:14 PM »
All big block engines were assembled at the Tonawanda (NY) engine plant.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Re: 1968 L/89
« Reply #5 on: March 23, 2011, 02:08:05 PM »
And both assembly plants built L89 cars.
L78racer
Re: 1968 L/89
« Reply #6 on: October 09, 2011, 04:52:27 PM »
Did the L89 use a different piston than the iron head?
Re: 1968 L/89
« Reply #7 on: October 09, 2011, 06:28:59 PM »
I'm assuming you mean different from the L78, and the answer would be no. Only difference between the L78 and L89 was the addition of the aluminum heads.
L78racer
Re: 1968 L/89
« Reply #8 on: October 09, 2011, 07:19:37 PM »
Thanks. I'm assuming the aluminum head also used a composite gasket. Wouldn't you take a compression hit by the thicker gasket?
Re: 1968 L/89
« Reply #9 on: October 09, 2011, 08:15:00 PM »
Yes, a different gasket was used. Cast iron L78 heads used the 3863199 gasket while the aluminum L89 heads used the 3921940 gasket. The "compressed thickness" probably had minimal effect, if any, on the compression ratio.
