Author Topic: Original 67-69 Camaro driveshafts - information requested about your car  (Read 340642 times)
Re: Original 67-69 Camaro driveshafts - information requested about your car
« Reply #180 on: February 27, 2016, 08:32:25 PM »
If you could...please measure from the center of one u joint to the center of the other.
Another way of saying that is "the center of each cap or cup that holds the needle bearings for the u joint".
« Last Edit: February 27, 2016, 11:07:18 PM by bcmiller »
« Reply #181 on: February 27, 2016, 11:03:22 PM »
Still soaking but I am starting to see the paint stripes better and better..
Looks good!  Thanks for the pic!
« Reply #182 on: February 28, 2016, 04:20:58 AM »
Would really like to have more data on any late 68 or 69 cars with the TH350 transmission.
Bump
cam69aro
  • 38,000 mile Jerry MacNeish certified z28
i can offer some info on my `69z, needs all the rubber replaced on the brake system so i`ll have all the wheels off it soon and will take some pics for you if needed. i can see the stripes on the driveshaft just looking under it so i know there is at least one visible.
Eldon W 1969 z28 Black with born with driveline X77 38,000 miles-sold
2016 z06/z07 Corvette Black
That would be great Eldon. It most likely has one orange and one white stripe, but if you could confirm, I would appreciate it. :)
cam69aro
will do, I`m bringing it to the Street machine nationals this weekend in St.Paul Mn. so when the show is done sunday it`s time for the brake restoration.
« Reply #187 on: December 10, 2016, 02:18:03 AM »
Eldon, did you have time to check your driveshaft?
Bump.
19674KCamaro
« Reply #189 on: October 16, 2017, 05:04:24 AM »
Does anyone have any info on the driveshaft for a 1967 L78 4K Camaro?  Trying to verify mine.
Everett#2390
  • ^Bess
« Reply #190 on: October 17, 2017, 01:48:14 AM »
The question is why are the U-joints out-of-phase?
The answer is for reducing vibrations.
Graph the power through a single U-joint and a sine wave is drawn. The joint speeds up, positive arc, and slows down, negative arc.
Add another U-joint and its power graph will have the same sine wave.
Add the two sine waves, if they are in-phase on the same shaft, and amplitude doubles, meaning the resultant twist is noticeable.
By offsetting one joint by 30°, decreases the amplitude of the associated twist, less vibration.
Now, driveshaft's having been built forever, and 1st Gen driveshaft's are different from typical design, may be due to the extreme angularity of drivetrain design on Camaro, i.e., wheelbase, length of shaft, OD and wall thickness, and critical speed of driveshaft.
Critical speed is important - it is rocket science. JMT's
« Reply #191 on: October 17, 2017, 02:44:46 AM »
What are the specs on the one you have?
« Reply #192 on: October 17, 2017, 02:45:47 AM »
The aren’t all “clocked” or out if phase.
Everett#2390
  • ^Bess
« Reply #193 on: October 17, 2017, 01:36:26 PM »
The aren’'t all “clocked” or out if phase.
True, I would think it depended upon application/options.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #194 on: October 17, 2017, 05:21:23 PM »
I have to disagree - that’s not how a double Cardan joint (U-joint) works.  Refer to page 3, 3rd post of this thread and search : driveshaft, rich69rs for other posts where this has been discussed previously.
I have my theory as to why Chevy did this - but since the forum hasn’t pursued the question seriously,  I haven’t either.  Of all the driveshafts built by all the auto makers, over all the years, ‘69 Camaro, SB, TH350, manual, and Powerglide got offset yokes, yet, as I recall BB w/TH400 transmissions didn’t???
As far as critical speeed (resonance) goes, offsetting the yokes will definitely stiffen the driveshaft and shift a natural frequency(cies) up - but at the expense of proper operation of a double u-joint system which is designed to keep the included angles of the driveshaft equal at all times.
With offset yokes, the included angle between the differential and the driveshaft will be different at all times from the included angle between the driveshaft and the transmission.  Stiffer driveshaft system? Undoubtedly.  Ideal for loading on either the diff or tans?  Not so much.  I modified my driveshaft to in line yokes back in 1991.
« Last Edit: October 17, 2017, 05:48:53 PM by rich69rs »
Richard Thomas
1969 RS
