Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
ignition coil
« previous
next »
Print
Pages: [
1
Author
Topic: ignition coil (Read 6001 times)
sebastien
Member
ignition coil
on:
May 24, 2006, 02:10:26 AM »
I have an ignition coil that I found among old parts,it reads
18-1040
12 volts
use with external resistor
1n25
any ideas what the application is?
Tweet
Logged
Sebastien 68 327 rag top
CRG Member
Re: ignition coil
Reply #1 on:
May 24, 2006, 04:55:58 PM »
That's probably an aftermarket replacement. "Use with external resistor" is commonly found on replacements.
Logged
Print
Pages: [
1
« previous
next »
Decoding/Numbers
ignition coil
