Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Mild Modifications
10 bolt disc on 12 bolt?
« previous
next »
Print
Pages: [
1
Author
Topic: 10 bolt disc on 12 bolt? (Read 9664 times)
mopar346
Member
on:
March 13, 2011, 01:51:17 AM »
I have access to a late 70s/early 80s Trans Am 10 bolt with disc and was wondering if they would fit on a first gen 12 bolt housing. I know that Chevy 10 bolt brakes will swap over, but wasn't sure about the Poncho 10 bolt disc set up. Anyone have any experience with this swap? I am thinking I remember folks swapping late Camaro disc to 12 bolts back in the day, but the memory is foggy only bits and pieces.
Tweet
Logged
vtfb68
Hero Member
Re: 10 bolt disc on 12 bolt?
Reply #1 on:
March 16, 2011, 10:25:25 PM »
340-6,
It'a a bolt in. you will need ALL the T/A parts inc. prop. valves, backing plates, Master cylinder, ect... the part that screws everybody is the axel slop. you will need thicker C clips or use two thinner C clips per side.
VT
Logged
68 08E LA RS Y2 749 L30 M35
67 11B LA RS/SS M-1 797-Z L48 M21 Convertible
mopar346
Member
Reply #2 on:
March 16, 2011, 10:42:12 PM »
Very interesting, thank you. I take it the original front disc set up on the 69 will work fine with them. Which booster should I use 69 or 79?
Logged
vtfb68
Hero Member
Reply #3 on:
March 16, 2011, 11:12:06 PM »
I never tried the old booster, or unbolted the M/C from the booster, (I was much poorer when I was younger did not even rebuild the parts - they came from a T-boned WS6) they should be the same.
VT
Logged
mopar346
Member
Reply #4 on:
March 16, 2011, 11:14:56 PM »
Cool, should be a cost effective upgrade.
Logged
tom
Hero Member
Reply #5 on:
March 17, 2011, 01:38:36 AM »
Good site with front conversion info:
http://www.pozziracing.com/brakes.htm#Converting_Drums_to_Discs
Logged
69 X11 Z21 L14 glide
o
mopar346
Member
Reply #6 on:
March 17, 2011, 11:14:10 PM »
Aleady have disc on the fron but I will read through it. Thanks for the link.
Logged
Print
Pages: [
1
« previous
next »
Mild Modifications
