Author Topic: Sway Bar End Links - Correct Finish & Bushings  (Read 16692 times)
Re: Sway Bar End Links - Correct Finish & Bushings
« Reply #15 on: March 04, 2011, 02:17:22 AM »
We are always learning so thank you! Wow, a 20K mile ram air 4! mama mia and a 6K 67 corvette. molta mama mia
John Z is bang on as usual!
The 6,000 mile 67 Corvette has WB2C bolts and the bushings are the small diameter ones the same size as the AMK Bushings B-10243 which show the GM part number # 381957.
 I also looked at his 70 Ram Air 4 Trans Am, 20,000 mile car, TOTALY original, it also has small diameter bushings and the WB bolts have WB only.
I have pulled off 1 of my original WB bolts, and I was surprised to find the bolt shank diameter is .342 ( 11/32") NOT 3/8" as I posted earlier. They do have 5/16 Thread on the top. The HBC bolts are the same diameter, as well as another set I have. I allways thought they were 3/8" but they are not.
The AMK small diameter bushings apprear to be correct at this time, and the hole size is smaller than 3/8 to correspond with original bolts. I also checked some Generic aftermarket link kits and they are 3/8" bolts with the larger diameter type bushings.
 Chick and Jeff - I Hope this helps.
rszmjt
« Reply #16 on: March 04, 2011, 03:26:07 AM »
 Chick,
Yea, the guy I work for has some great original survivor cars, it is a great source of info, I learn something everytime I look at them.
jeff68
« Reply #17 on: March 05, 2011, 09:41:40 PM »
My original bolts are marked EWF with the 3 hash marks of a Grade 5 bolt.  They have a measured shank diameter of .372"
The washers are 1.44" in diameter and .12" thick.
luv2sixty9
« Reply #18 on: April 01, 2011, 01:51:41 PM »
I have a TRUE NOS kit that I purchased years ago. They have the smaller diameter bushings. Also the hardware is not silver cad, but a phos or natural finish. BTW the bolt head markings are WB.
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
