Author Topic: what is the correct front wheel backspacing on a 1968 with 15" x 7" rally wheels  (Read 9481 times)
malley67
hi guys,
hope you can help me.
i have a 1968 camaro with 15" x 7" rally wheels and firestone firehawke tyres p215/65r15.
i have been told these wheels and tyres should be fine, but when i hit a dip in the road my front tyres rub / scrape against the wheel arch trim.
i am wondering if the back spacing is incorrect and would like to know what it should be ?
any help would be appreciated.
thanks guys,
rohan
BlackoutSteve
Did they ever have 15x7" Ralleys?
Anyway 4.25" works well.  ;)
tom
    • Discount Internet Services
Yes, 15 x 7 ralleys were on Z's
http://www.camaros.org/suspen.shtml#Wheels
69 X11 Z21 L14 glide
o
x66 714
Not in 68. 15x6 was the largest wheel on a Camaro including the z/28....Joe
vtfb68
I think the tires are a bit tall for the front. Scrapping the wheelwells or just the trim?
  VT
68 08E LA RS Y2 749 L30 M35
malley67
hi vt,
thanks to all who have replied.
the tyre definately scrapes the wheel trim, as it gets bent out after i drive it. not sure if it scrubs the wheel well.
also, should there be a gap between the trim ring and the centre on the wheel ?
my wheels have a gap of about 20mm between the trim ring and the the centre of the wheel ?
thanks guys,
rohan
vtfb68
Rohan,
I used factory 15 x 7 rallys, 215 60 15 BFG T/A's for years with lower springs and never had a problem. I also mounted 215 65 15 Firestones that were very tall and square that rubbed on every driveway and dip. That gap seems very wide, Make sure the rings are correct. Are they bottoming out? Also check the clip location.
  VT
malley67
vt,
thanks very much,
trim rings arnt bottoming out.
how do i check / what is the correct clip location ?
so the trim ring should butt up against the centre of the wheel ?
cheers,
rohan
