Author Topic: 68 fuel gauge  (Read 5617 times)
68 fuel gauge
« on: February 20, 2011, 02:56:44 AM »
Is this the resistor that is used for the dash fuel gauge (the white thing at the bottom)?  Or does something go on the outside between the two nuts on the back of the pod?
Re: 68 fuel gauge
« Reply #1 on: February 21, 2011, 11:02:30 PM »
Again
Mark
Re: 68 fuel gauge
« Reply #2 on: February 22, 2011, 02:06:33 AM »
Yes, thats the gauges wire wound resistor, should measure somewhere around 46 ohms I think.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
Re: 68 fuel gauge
« Reply #3 on: February 22, 2011, 04:59:44 AM »
Thanks Mark.
Re: 68 fuel gauge
« Reply #4 on: May 07, 2011, 10:56:17 PM »
Can I check resistance with that thing the way it is or do I have to take it off?  I'm getting ready to put this in and don't want to have to take it off again if something doesn't work.  Also, does something connect to those nuts on the back or does the gauge work from the connector that plugs into the pod?
flyingskibiker
Re: 68 fuel gauge
« Reply #5 on: May 10, 2011, 03:36:31 AM »
The signals come from the plug and through the circuit board.
Re: 68 fuel gauge
« Reply #6 on: May 10, 2011, 10:15:14 PM »
Good, thanks.
