Author Topic: front fender bolt finish  (Read 5816 times)
rskev
« on: February 18, 2011, 08:50:38 PM »
Hello all! Just curious about the correct fender bolt finish for my 68' RS. Specifically, I'm referring to the bolts that hold the front fenders to the top of the radiator support. Are these supposed to be black phosphate or painted to match the body color? Thanks to anyone with advise!
tmodel66
Re: front fender bolt finish
« Reply #1 on: February 18, 2011, 09:21:50 PM »
None of the bolts are body color.
rskev
« Reply #2 on: February 25, 2011, 07:00:28 PM »
thank you!
« Reply #3 on: March 02, 2011, 12:16:25 AM »
Black Phosphate.... Lot's of information on this subject if you do some searches.
john302
« Reply #4 on: March 04, 2011, 03:25:49 AM »
Black phosphate is the correct plating. I also bead blast the bolts before plating.Also spray some type of oil on them before installing them to prevent rust . Put alittle strip caulk on the washer to prevent peeling the paint when tighting. John
