Author Topic: FISHER BODY MEASUREMENT  (Read 14017 times)
Dave69rag
« on: February 08, 2011, 01:48:55 AM »
I am quite sure that this may have been asked before, however, I had no luck searching for definitive answer.  I am trying to find out the rear frame rail spacing on a first generation Camaro.  The measurement I need verification on is the "K" dimension shown in the Fisher Body manual.  This measurement is taken between the inboard edges of the rear frame rails at the centerline of the rear shackle bolt hole.  The Fisher Body manual is showing 42 7/8".  I have found some information that stated that the Fisher Body manual is incorrect and the actual measurement is 43 7/8.  My project car has a dented and rusted frame rail, so I could not accurately verify this measurement.  Any assistance would be greatly appreciated.
Dave
dutch
Re: FISHER BODY MEASUREMENT
« Reply #1 on: February 08, 2011, 04:50:42 AM »
Dave, there are quite a few guys doing complete body rebuilds - some with very long threads going describing them in great detail (along with exchanges of lots of measurements involving the framerails and wheel tubs etc) over on the Team Camaro site / forums / body shop - check it out...
 http://www.camaros.net/forums/forumdisplay.php?f=12
Randy
« Reply #2 on: February 08, 2011, 05:43:22 AM »
Dave,
K = 43 7/8" at this website...   http://1stgencamaro.net/frame.htm
Dave69rag
« Reply #3 on: February 08, 2011, 01:45:23 PM »
Thanks for the responses.  I still do not know what measurement is correct.  There has to be someone on this site that has some first hand knowledge of the correct measurement.  Hopefully they will read this post and let me know.
rodent
« Reply #4 on: February 08, 2011, 06:33:19 PM »
Dave,
There are a few measurements on that website that are different to the Fisher body manual?
67 RS Ragtop
« Reply #5 on: February 11, 2011, 03:24:03 AM »
Dave,
  If you are still concerned about this dimension, I will happily measure my 67 for you, as they are the original rails - advise please.
Dave69rag
« Reply #6 on: February 11, 2011, 02:36:46 PM »
I would appreciate the measurement.
67 RS Ragtop
« Reply #7 on: February 13, 2011, 04:50:12 AM »
My 67 measures 43 and 15/16 wide, so I would assume the 43 and 7/8 would be a correct measurement. The measurement was taken inside the rails, just below centerline of the shackle bushing mount areas.
Dave69rag
« Reply #8 on: February 13, 2011, 02:31:27 PM »
67 RS Ragtop - thanks for taking the time to get the measurement for me.  Since I first posted the question, I have been able to take measurements from 2 cars.  Of course, each one was different.  If anyone has a free moment and could measure the frame rail spacing, it would be appreciated.  If I had a few more verified measurements, it would help.
Dave
CJP_69
« Reply #9 on: February 18, 2011, 07:22:18 PM »
Dave,
For whatever it is worth, I took several measurements. The rear springs and tank are out of my 69 pace car. Measuring inboard edge to inboard edge, using a stanley fatmax tape measure with bushings and a bolt in place to get the centerline, I came up with 42 1/2". Went right to left, left to right, several times to eliminate any possible error on my part. I also did this on my 69 x22 coupe drag car, which still has factory rails, but has coil overs and a fuel cell in the trunk. I came up with 42 9/16". Both cars have the original rails. Hope this helps.
Chris
Chris
Dave69rag
« Reply #10 on: February 20, 2011, 03:33:24 PM »
Chris,
Thanks for the reply.  I appreciate it.
Dave
