Author Topic: RPO MA6  (Read 15666 times)
Dusk_Blue_Z
RPO MA6
« on: January 28, 2011, 04:21:49 PM »
Are there any known/documented 69's that had the HD Dual Disc Clutch? I've read Wayne Guinn's article on the RPO many times and am intrigued by it.
Nick
1969 X77 01B 51 51 flat hood
Re: RPO MA6
« Reply #1 on: January 28, 2011, 10:17:02 PM »
None in the database and it's fairly certain the MA6 never made it into production for the Camaro. Corvette yes, but even then only 102 cars!
Re: RPO MA6
« Reply #2 on: January 29, 2011, 06:41:57 AM »
I believe Charley Lillard had a documented '69 Z once where the original owner ordered the MA6 and it wasn't built with that option. Not sure if that means it was never actually available or if it just was not available at the time the car actually got built.
-Jon
Re: RPO MA6
« Reply #3 on: January 30, 2011, 03:18:23 AM »
Production totals for MA6 in a Camaro was the big zero. Engine build records confirm it.
Re: RPO MA6
« Reply #4 on: January 30, 2011, 03:51:53 AM »
Engine suffix codes reserved for use with MA6 heavy-duty clutch (none known to have been produced)...
L48 - HP
L35 - JU
L34 - KA
L78 - KC
L89 - KE
Re: RPO MA6
« Reply #5 on: January 31, 2011, 12:44:00 AM »
The MA6 clutch was available on '69 Corvettes (only on the 3x2 L-71 and 3x2 L-71/L-89), and 102 were sold (out of 38,762 Corvettes); they were a warranty nightmare and were never offered again.
Re: RPO MA6
« Reply #6 on: January 31, 2011, 03:35:36 AM »
The MA6 clutch was available on '69 Corvettes; they were a warranty nightmare and were never offered again.
John,
What was the problem with them?
Re: RPO MA6
« Reply #7 on: January 31, 2011, 04:09:14 PM »
John,
Mostly noise/vibration - chatter from the floater plate.
Re: RPO MA6
« Reply #8 on: January 31, 2011, 10:46:44 PM »
I drove a cement truck for years that had the double clutch plates in them and they made a lot of noise with the clutch in.
Re: RPO MA6
« Reply #9 on: January 31, 2011, 11:30:39 PM »
Like the Ducati dry clutch...
http://www.youtube.com/watch?v=QuU8ung70RA
Re: RPO MA6
« Reply #10 on: April 27, 2011, 10:41:13 PM »
I though I remembering reading that Olds offered the dual disc clutch in 70, or was that my projecting onto/into the haze?
rat pack
Re: RPO MA6
« Reply #11 on: April 28, 2011, 04:15:58 PM »
The heavy duty dual disc clutch RPO W37 was offered by Oldsmobile in 71 & 72. In 71 it only required the M20 or M22 option & 442, but in 72 they made it engine specific with the L75 & L77 engines in any model of Cutlass with the M20 trans.............RatPack..................
Re: RPO MA6
« Reply #12 on: May 02, 2011, 12:11:40 AM »
Wow, my memory does serve... every once in a while. ;)
Re: RPO MA6
« Reply #13 on: May 10, 2011, 10:26:59 PM »
Photo of the MA6 clutch in the March '70 issue of Motor Trend.
69znut
Re: RPO MA6
« Reply #14 on: July 02, 2011, 03:24:15 AM »
Read here http://www.yearone.com/enthusiast/restoarchives/summer96/sum96best-kept-secrets/camaro.htm
L48 - HP
L35 - JU
L34 - KA
L78 - KC
L89 - KE
