Author Topic: 67 12 bolt posi  (Read 12889 times)
mopar346
67 12 bolt posi
« on: January 28, 2011, 02:46:50 AM »
I scored a 67 (i believe) 12 bolt posi at the Turkey rod run this year for $200. My question is, is it rare enough that I would be better off selling it and buying a 69 housing or offering it up for trade for a 69 unit. I know that I can change the spring perches and run it with no issue (after rebuild of course) and I don't really care about dates but many do. I just have enough respect for a rare or hard to find date code that I would hate to use it where it doesn't matter if it is a rare housing. Not looking to make a profit just end up with a 12 bolt. So what do ya'll think, is it rare or hard to find?
Re: 67 12 bolt posi
« Reply #1 on: January 28, 2011, 03:04:23 AM »
67 Camaro 12 bolt axles are hard to find. Many are getting modified for early Novas. If it is a posi with 3:55, 3:73 or lower gears it is valuable. Does it have the T-bar bracket?
Nothing wrong with making a few bucks on it to get into a '69 axle.
Re: 67 12 bolt posi
« Reply #2 on: January 28, 2011, 03:46:56 AM »
mopar346
Re: 67 12 bolt posi
« Reply #3 on: January 28, 2011, 03:49:07 AM »
I believe it is a 2.73 gear which is no big deal to me as it needs to be built anyway. The carrier is not diiferent is it? I don't believe it has the traction bar bracket if that is what you are referring to, but I can double check when I get home. Passenger side lower slightly forward location? Got a picture?
mopar346
Re: 67 12 bolt posi
« Reply #4 on: January 28, 2011, 03:50:25 AM »
That's pretty good, you posted the picture before I ask.
mopar346
Re: 67 12 bolt posi
« Reply #5 on: January 28, 2011, 03:53:29 AM »
No offense but Chevys are so dull with their all black suspension.  ;D
tom
    • Discount Internet Services
Re: 67 12 bolt posi
« Reply #6 on: January 28, 2011, 05:43:13 AM »
I think there were 3 different carriers, and the 2.73 carrier was not compatable with the more desireable high performance ratios. Of course if I'm wrong, someone will post the truth
69 X11 Z21 L14 glide
o
mopar346
Re: 67 12 bolt posi
« Reply #7 on: January 30, 2011, 12:41:37 AM »
It doesn't have the traction bar bracket but it appears on quick inspection it may have had something welded to it at one time. I will check further tomorrow, I will also check the gears again. Where are the date codes on the housing I will double check that as well.
Gramps69Z
  • 69 X33 D80
Captain John Wykoff
mopar346
Re: 67 12 bolt posi
« Reply #9 on: February 04, 2011, 06:55:34 PM »
Axle code is BY 0914 G2
BY        68 only 2.73 12 bolt posi
09        Semtember
14        14th
G         Detriot
2          2nd shift
Correct?
Re: 67 12 bolt posi
« Reply #10 on: February 04, 2011, 07:25:06 PM »
Quote
09        Semtember
14        14th
G         Detriot
2          2nd shift
Correct?
You are correct.
mopar346
Re: 67 12 bolt posi
« Reply #11 on: February 04, 2011, 08:25:19 PM »
Thanks. So it was for a 68 model year. Who in their right mind or what package would have had a 2.73 with a posi no less? Just don't make sense the way I think. If I understood an earlier post the carrier is pretty much useless since it wont hold a steep gear. Is there a spacer available and if so how reliable/durable are they?
Re: 67 12 bolt posi
« Reply #12 on: February 04, 2011, 08:55:32 PM »
The 2.73 could be had with just about any engine if you pressed hard enough, but typically, the "economy ratios" of the L30, L48, L35 and L34 engines had the 2.73 available. Heck, with a few engines you could even get a 2.56 ratio!
mopar346
Re: 67 12 bolt posi
« Reply #13 on: February 04, 2011, 09:00:00 PM »
What all gears will fit the carrier?
Re: 67 12 bolt posi
« Reply #14 on: February 04, 2011, 09:20:18 PM »
The 2 series carrier will support the 2.29 (1969 full size cars), 2.56 and 2.73.
