Author Topic: Rear end torque specs  (Read 9426 times)
mopar346
« on: January 14, 2011, 01:46:36 AM »
Sorry to ask another truck question on here, but I gotta finish his truck before we can start his Camaro. Anyway the truck sight I joined just seems to have little to no activities at times. The question is about the torque fior the rear end bearing caps. It is a 14 bolt semi-floating axle 9.5 inch ring gear unit. I am upgrading it from his 10 bolt and then torque I can find is 135lb which seem really high yo me, most of the references are for the 10.5 ring gear full floating units. I did find one listing for 63lbs for the 9.5 but that almost seems low. Does anyone knwo for sure?
Thanks for the tolerance, Kevin
Boston14
Re: Rear end torque specs
« Reply #1 on: January 14, 2011, 03:37:19 AM »
What year, make, model, and GVW did the truck rear axle come from?
boston14
boston14
1969 SS/RS 350 Convertible
mopar346
« Reply #2 on: January 14, 2011, 03:09:39 PM »
91 Chevy 3/4 ton 4X4 short cab long bed. Don't know the exact GVW but I would quess 7000ish
Boston14
« Reply #3 on: January 15, 2011, 12:37:02 PM »
Mitchell's Repair On Demand lists 9 1/2" ring gear side carrier bearing caps at 60 ft.lbs. for a 91 Chevy K2500. All of Mitchell's specs are directly from GM. Hope this helps.
boston14
boston14
mopar346
« Reply #4 on: January 16, 2011, 12:14:07 AM »
Thank you, having access to such info is very important. I just knew 135 was way too high and I didn't want to snap a cap bolt.
mopar346
« Reply #5 on: January 18, 2011, 03:03:54 AM »
Well its done and queit. The brakes are trying to put him through the windsheild since they are 13 inch. Kinda funny.
Thanks again for the help.
