Author Topic: Question on Splash Sheild Clip for '68  (Read 12495 times)
cadmanof50s
  • Vic Brincat
« on: December 22, 2010, 07:07:55 PM »
Looking to source a clip for my '68. The clip is used to hold up an obscure section of fender splash shield on the left side. I found all kinds of splash shield kits ..but nothing for this clip..
You can see the clip on the first picture of this post..
http://www.camaros.net/forums/showthread.php?t=71611
You can also find it in the 68 Assembly manual, UPC 11-13 Sheet B1. The part number is called 3921872 Clip
Thanks for your help.
Vic Brincat
'68 Camaro RS Convertible
« Last Edit: December 22, 2010, 07:32:03 PM by vicbrincat »
Vic Brincat
1968 Camaro RS Convertible - 327
jacmac
Re: Question on Splash Sheild Clip for '68
« Reply #1 on: December 23, 2010, 01:05:04 AM »
Looks the same as my 69, same part number.I dont see it in my Classic Industries or Rcks catalog.Sorry I could not be more help
68rs327conv
    • The build
68 RS Conv 327/210hp, Powerglide Factory AC
cadmanof50s
  • Vic Brincat
« Reply #3 on: January 11, 2011, 09:48:12 PM »
Thanks Mike!
Vic
Vic Brincat
BlackoutSteve
« Reply #4 on: January 12, 2011, 10:37:47 AM »
Vic, scroll down to post #25 of that thread-link you posted..
You may need to do what I did and make one!
It was very easy.  ;)
cadmanof50s
  • Vic Brincat
« Reply #5 on: January 12, 2011, 01:55:04 PM »
Thanks Steve. I will ceratinly make one if all else fails. I have downloaded your pics to use for a blueprint.
Thanks again for the post!
Vic
Vic Brincat
« Reply #6 on: January 13, 2011, 05:06:42 PM »
Vic
Vic, I have mine out of the car and recently glass beaded it. If you need some other pictures or dimensions let me know.
« Reply #7 on: January 13, 2011, 05:19:24 PM »
They are made from Spring Steel and appear to be heat treated/blued
here is a refinshed one...
cadmanof50s
  • Vic Brincat
« Reply #8 on: January 13, 2011, 07:09:50 PM »
Thanks folks!
68camaroz28 if you could take two minutes and post dimensions it would be greatly appreciated.
Thanks again.
Vic
Vic Brincat
« Reply #9 on: January 14, 2011, 01:37:32 AM »
Angle is approximately 10 degrees.
cadmanof50s
  • Vic Brincat
« Reply #10 on: January 14, 2011, 05:11:33 AM »
Many thanks 68camaroz28,  for taking the time to do this. The pics are exactly what I need.
I'm sure others will find this information useful as well.
Vic Brincat
Marty
« Reply #11 on: January 30, 2011, 08:32:50 PM »
Vic, I found an extra clip in one of my parts boxes today. If you're interested send me an email.
Martin Foltz
Martin Foltz
CRG Member
68 Van Nuys Camaro
