Author Topic: Correct steering box finish  (Read 21585 times)
rskev
« on: December 22, 2010, 01:06:20 AM »
I was looking for any tips/advise on painting or restoring the finish on the power steering box on my 68' RS. I'm told by some that it was originally a natural finish, while others say black, or "spray gray" from Eastwoods, and so on. Can anyone recommend a spray paint that looks good and is still "correct"? Thank you!
Re: Correct steering box finish
« Reply #1 on: December 22, 2010, 03:47:17 AM »
« Reply #2 on: December 22, 2010, 04:46:17 AM »
Jerry has our manual steering box currently to restore.
cadmanof50s
  • Vic Brincat
« Reply #3 on: December 22, 2010, 06:15:43 PM »
I am at this same stage of restoration with my '68.
Reading through the previous threads, it would seem that the boxes were basically left unpainted.
Mine had been previously painted..aluminium color.
Once I strip it of paint should I leave it without a finish so it can rust again?
Since it was cast, can I use a cast-iron engine paint on it and make it "look" somewhat correct?
Suggestions?
Vic
Vic Brincat
1968 Camaro RS Convertible - 327
rskev
« Reply #4 on: December 22, 2010, 08:39:52 PM »
Vic, That's the same spot I'm in. I'd like to paint it with something so that it looks correct, but will last a long time. I'd prefer it not to rust again it I strip it. I guess I'm looking for the same answer.
lakeholme
  • 68-12D L30/M35
« Reply #5 on: December 23, 2010, 02:39:09 PM »
Read Jerry's post in the thread Paul referenced above.
rskev
« Reply #6 on: December 23, 2010, 06:56:42 PM »
Thank you!
BlackoutSteve
« Reply #7 on: December 23, 2010, 10:05:21 PM »
I bought #32020  "OEM PAINTS STEERING GEAR BOX FINISH, DARK GRAPHITE"
Is the color accurate?
x77-69z28
« Reply #8 on: December 24, 2010, 02:03:00 AM »
looks too dark to me
Gramps69Z
  • 69 X33 D80
« Reply #9 on: December 24, 2010, 03:29:57 AM »
On page 206 of Jerry's 4th ed. book the steering box is a natural metal finish.
Captain John Wykoff
MyRed67
  • SZZLN 67
« Reply #10 on: December 24, 2010, 04:38:40 AM »
 I have used Martin Senour TECnique Iron Cast #7250.  I forget who suggested it, but I believe it was on here.  Works great, looks great, it is a flat or semi-gloss finish so it's not too glossy.  It's available at NAPA in a big 15 oz. spray can for 'I believe' about $8.99.  FYI - the top cover, and the round disc in the end should remain natural aluminum color.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
« Reply #11 on: December 24, 2010, 04:42:05 AM »
Any aerosol cast finish does not provide an adequate water barrier. Epoxy all parts first.
BlackoutSteve
« Reply #12 on: December 24, 2010, 05:22:12 AM »
That's the finish I want, but without the surface rust. :p
9T4Z
    • Gary's Camaro
« Reply #13 on: December 26, 2010, 04:32:01 PM »
Hello.... may be of assistance.  When I've stripped parts that were supposed to be bare metal, I've elected to clear coat with a flat sheen clear coat.  Looks pretty good and rust does not come back.
Gary 9T4Z
94Z rag blower 491 rwhp (now 505!)
69 Pace Car, 70RS,91Z,91RS
« Reply #14 on: December 26, 2010, 05:09:28 PM »
What did you use as a clearcoat? There are many. Unless they have perfected the adhesion properties of clear recently, I have not seen long term stability on bare metal. Especially any lacquer based clears, which most aerosols are. In the link below are Dave's test pictures of product failure. I always epoxy parts prior to topcoating with Cast Blast if not left in bare metal. Cast Blast alone provides a poor water barrier. As does any lacquer based product and those containing talc. http://www.camaros.org/forum/index.php?topic=3951.0
