Author Topic: Spark plug wire Heat shields  (Read 20797 times)
bc69
« on: December 18, 2010, 06:07:46 AM »
Anyone know if the shields that D&R selling now (newly retooled) Correct? Are there better choices?
Brad
RSSS
Re: Spark plug wire Heat shields
« Reply #1 on: December 18, 2010, 07:08:41 AM »
bc69
« Reply #2 on: December 18, 2010, 08:28:04 PM »
D&R has in their description that they have retooled and I am wondering if they are still (correct) as when Jerry made his comment in 08..?? The above threads are in 08.
Brad
RSSS
Jerry@CHP
« Reply #3 on: December 19, 2010, 04:30:47 AM »
Should be, I have them in stock for engines that we rebuild.  Best available.  Two are spot welded and two screw together.
Jerry
bc69
« Reply #4 on: December 19, 2010, 06:04:15 AM »
Thanks Looked up online and their it is as you stated. My hard copy of theirs gives a little diff description.
Brad
RSSS
john302
« Reply #5 on: December 24, 2010, 11:08:20 PM »
Just installed a set of the repops.Very nice pieces with alittle work they fit real good. One thing that is wrong is the plating.The original plating is silver cad not galvinized. The other thing is nobody ever installs them correctly.The two spot welded ones go on the right side and the other two go on the left. Also the two mounts on the left are painted orange not plated. John p.s. the bolts on the left are painted also
rskev
« Reply #6 on: December 25, 2010, 08:04:12 PM »
Does anyone have the website address or contact info for d&r? I googled them, but nothing came up. Thank you!
Boston14
« Reply #7 on: December 25, 2010, 08:50:52 PM »
I bought mine there as well, good product.
www.drclassic.com
boston14
boston14
1969 SS/RS 350 Convertible
bowtie68iho
« Reply #8 on: January 04, 2011, 03:03:54 AM »
John302,
How did you determine that the bolts and mounts on the left side were painted?  Did a car of yours get hit on this by a Legends Judge?  I'd like to be absolutely sure before I paint mine for the upcoming Nationals.
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
john302
« Reply #9 on: January 04, 2011, 01:57:12 PM »
Never had a car judged.I learned it on my own. My original never taken apart 68z has them orange. If you think about it the mounts go on before the manifold on the left side. Nobody else ever picked up on this detail item. All of the engine I do are done correctly. It doesnt matter to me what the judges say this is the correct way. John Allouez Restoration p.s. go to the 67z web site and look at the pics of Jon Mellos mountain green 67 .It shows the original early take off shields in one of the pics.
1968 Z28
« Reply #10 on: January 04, 2011, 02:50:26 PM »
I agree with you, John.  I know when I disassembled my original '68 engine, the left brackets and the bolts that mounted them to the block were painted orange....indicating to me that they were mounted to the engine when it was painted at the factory.  The shields were apparently added later at the assembly line....along with the right side ones.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Charley
« Reply #11 on: January 04, 2011, 02:55:22 PM »
Look in the body section of my Z28 site and you will see pics showing the drivers side ones painted and the pass side ones plated. No I don't know why they ended up in the body section.
bowtie68iho
« Reply #12 on: January 08, 2011, 02:01:41 AM »
Hey, everybody, guess what I just found!  I just looked on page 6/B5 of the 1968 Factory Assembly Instruction Manual and View C of the drawing shows both left-hand side mounts and their screws (GM #274430) as "PART OF ENGINE."
This validates john302, Sonet, and Charley that these left-hand mounts and screws were already on the engine when it was painted red-orange.  Woohoo!
deejaygee
« Reply #13 on: January 08, 2011, 04:05:31 AM »
Here is a photo of the spark plug shields that were removed on Day 1 to install headers on Jon Mello's survivor 67 Z28:
« Reply #14 on: January 14, 2011, 11:36:55 PM »
My ears are burning. Did I hear somebody say Jon Mello? :)
