Author Topic: 67-68-69 hoods  (Read 11254 times)
phils_crew
  • Guest
67-68-69 hoods
« on: December 10, 2010, 03:48:03 AM »
  hi,
 still newb here.reading the threads i had seen something about orginal gm hoods having a #`s
or something stamped into seam or lip that id `s info about it.even saw a pic how to tell gm from
aftermarket.near hood hinge drivers side.where exactly do i look?i have 2- 67`s and have 5 extra
hoods to look thru.(put better 1`s on my cars).1 is for sure aftermarket.one on car in cold storage
is cowl that has a air valve looks to operate (has actuator) wire but no plugin.i was told it was gm
but loved it was perfect (paint and straight).paint was very nice blue green color w/white stripes
on either side of centerline,from header end to cowl end. that  z? maybe ? any help appreiated.
tryed to find those threads again,feel like blind bumping around unfamilar place.as it is here.. lol
Gramps69Z
  • 69 X33 D80
Re: 67-68-69 hoods
« Reply #1 on: December 10, 2010, 04:51:27 AM »
 Advanced search= type in hoods and read away.  ;)
Captain John Wykoff
vtfb68
Re: 67-68-69 hoods
« Reply #2 on: December 10, 2010, 05:15:55 AM »
Look on the side of the hood all the way in the corner on the rear side. On original hoods there will be faint stamps indicating the week it was built.
  VT
68 08E LA RS Y2 749 L30 M35
babaron
  • 1969 L78 convertble
Re: 67-68-69 hoods
« Reply #3 on: December 11, 2010, 10:26:47 PM »
? picture? , mine is a '69
Enjoy Life!
phils_crew
  • Guest
Re: 67-68-69 hoods
« Reply #4 on: December 12, 2010, 06:57:55 PM »
  ok,went down to barn.(car is in cold storage there)had to resize jpeg hope its not to small now.
phils_crew
  • Guest
Re: 67-68-69 hoods
« Reply #5 on: December 14, 2010, 10:35:29 AM »
   hey,
     finally got other pix re sized to post. any help about what and how to use this .how does it
 hook   up? is it kick down or maybe 12 v dc? opens on start up or when?  choke ? ever seen
anything like it?  any help or comments ...lol ....phil
IZRSSS
  • Guest
Re: 67-68-69 hoods
« Reply #6 on: December 14, 2010, 01:34:21 PM »
Phil...just a thought. When you downsize your pics try keeping your KB < but as close to 100KB as possible.
Re: 67-68-69 hoods
« Reply #7 on: December 14, 2010, 02:46:31 PM »
   hey,
That's the ZL2 Special Ducted Hood option, covered in detail in the ZL2 section of your '69 Assembly Manual. There's a plunger-type switch mounted on the accelerator lever on the firewall; when you go to wide-open throttle, the switch closes, activating a relay that mounts above the heater blower housing. The relay triggers the solenoid mounted in the hood, which opens a flap in the rear of the duct in the hood, allowing cooler outside air directly into the air cleaner (and a great induction roar).
Gramps69Z
  • 69 X33 D80
Re: 67-68-69 hoods
« Reply #8 on: December 14, 2010, 03:04:18 PM »
Phil, I thought I would let you know the ZL2 hood was not available for 67's or 68's, but there's a poop load with them.
Per: CRG
Cowl hood (ZL2): The cowl hood was an option on SS and Z28 models in 1969 and was included on all COPO's and Pace Cars. It was introduced midyear 69 and the first known Camaro to have one from the factory was the #1 ZL1, built 12E. No documented cowl hood car before 12E has been found. The ZL2 option included a solenoid and flapper in the hood. The wiring for the solenoid was routed thru a special hole in firewall above the fuseblock. Only 10,026 cars received cowl hoods in 69 and about half of those went to COPO's and Pace Cars, meaning there were only 5,000 Z28's and SS's (out of about 20,000 Z28's and 30,000 non-Pacer SS's) that received the cowl hood.
Captain John Wykoff
phils_crew
  • Guest
Re: 67-68-69 hoods
« Reply #9 on: December 15, 2010, 12:09:15 AM »
 :o
    thanks  john  wyk   and everyone who replied. i will try to get code for crg database when i find
where it is.any thoughts as to the turquoise color it was? my 67 camaro 6 was a LL turquoise not quite pleaseing to me.(the one pix w/profile)is now a 74 caddy blue w/metal flake.the old paint seen its better days i had favored the 2010 impala imperial blue ..until i got this hood..i flat blacked it
 to avoid such stark contrast.(as you can see thru thin spots,) some color is visable.may repaint it the 6, that color.. its a 69 color ?what would be the code or correct # for it?
   any interest in the ZL2 hood would be seriously considered.my cars are 67`s...phil
MyRed67
  • SZZLN 67
Re: 67-68-69 hoods
« Reply #10 on: December 15, 2010, 06:30:17 AM »
Go to this link for picture of hood date code;
http://www.camaros.org/forum/index.php?topic=6696.0
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
phils_crew
  • Guest
Re: 67-68-69 hoods
« Reply #11 on: December 15, 2010, 09:17:05 PM »
thanks my red,
  i have found the code on 2 of my hoods .both have gm notch.1 is stamped on the camaro 6
(which was a norwood  jan. 67 build date car.the ole turquoise paint dead giveaway) at least i now
know which one it is...lol.the other is a 12 stamped in hood of which had the forward facing
 speedway( mailbox )fiberglass scoop that was on the car when i got it in 1979.
the ZL-2 hood doesn`t have the gm notch and no suprise no stamping.after re-reading the hood
posts from the past it does bear out crg consences that very few original ZL-2 hoods would have
been separated from the car it was born to.i had seen ads that aftermarket hoods that could be
fit w/parts (sold separately) to make it functional.it would seem i have 1 of those.and one that
could never be fitted as there is nothing to mount it too.so much for the 69 turquoise color!lol
  the previous owner of my rs took hood and deck lid for a 67 z28 that he had also got about the
same time as the rs.swap to keep the z more original and so sorry the rs got those aftermarket parts.
which hood would you use on the rs? the 1 or the 12  ...lmao now..thanks for the input..phil
MyRed67
  • SZZLN 67
Re: 67-68-69 hoods
« Reply #12 on: December 16, 2010, 04:06:47 AM »
phil_  What was the build week of your car?  The 2 digit code on the hood is build week.  From what I have found, the body panel date code should be 1 to 3 weeks before the car build date.  The link above hood build date is week 43, my car is an 11 A (66) build date and as near as I can figure that is week 45.  All body panel date codes I have found are 42 to 44.
1967 Camaro  LOS  11A
phils_crew
  • Guest
Re: 67-68-69 hoods
« Reply #13 on: December 18, 2010, 06:07:40 PM »
 hey myred67,
  thanks for link , wish my stamps took that great pix.the camaro 6 is a 01a build car.the color is HH.
guess thats mountain green instead,but fact remains the stamp is single digit  1  that almost
missed the edge of hood.the  other hood w/scoop  also a at very edge of hood and is 12.the
top loop of two is missing,off edge. i would guess its march..that fits the 03D build  RS,and as
previous owner took its.. to put on his 67 Z28 (that is so much more the important car) that
with all that rusted out and needed replaced on the rs .it dont matter much such a lesser car is
not worth saving to so many of purist here.still glad to have helped someone (w/cancer) that
is if it wasn`t just a ruse.and save what i could of a car i consider worty of  it.makes all those
true surviors worth their weight in gold.and those companies making teens thousand $ shells
the real suckers bet..so the cars `ll be re-built my way,cause i don`t care what purist think and
thats why this site (with so much to share )only has limited members..and car clubs too are in same
boat.this is my last post.if ya got a survior enjoy it,if ya got a modify it to be happy..do it...phil
Ericamaro
Re: 67-68-69 hoods
« Reply #14 on: January 26, 2011, 05:16:18 AM »
i like how it says newbie. i am newbie post wise. yet i have check forum constantly for many years. thanks for your input. will check link. guess u cant resist buy parts either.  5 hoods
