Author Topic: Paint under Cowl Pannel - color Z11  (Read 12297 times)
srode
« on: December 04, 2010, 05:36:34 PM »
Ok, I did a search but didn't find exactly what I was looking for on the topic.  Z11 under the cowl panel where you can see through the vent, what color(s) are supposed to be where?  I understand the wiper linkage rods are flat black from other posts, but what about the well and the panel directly under the cowl - Orange, Dover White, or Flat Black.   The person restoring my car insistes its white with th well area flat black, I'm thinking it's all hugger orange.
Also, are the color(s) over spray or full paint?
thanks, Steve
Re: Paint under Cowl Pannel - color Z11
« Reply #1 on: December 04, 2010, 06:18:23 PM »
The cowl was masked and the areas under the grilles painted orange. This was done after the car was painted so the remainder of the cowl top was white.
Nothing was flat black. The wiper linkage was probably flow-coated semi-gloss black.
srode
« Reply #2 on: December 04, 2010, 07:32:42 PM »
Thanks William.  I'll have everything under the cowl painted orange so all you can see is orange when you look through the grill with the exception of the wiper arms.   Just out of curiosity, is this the same for all cars with stripes?  Example: Z28 with white stripes and body color lemans blue would be all white when you look through the cowl grill?
« Reply #3 on: December 04, 2010, 08:59:12 PM »
The quality and coverage of stripe color on the cowl varies.
Early Norwood cars were very sloppy. There is an original photo of a Novermber '68 built Z/28 on page 120 of JM's '69 book. White paint extends completely down the firewall. On later cars it is limited to the top of the cowl and eventually is confined to the areas under the grilles. Van Nuys is probably a bit different.
GaryL
  • Marilyn and me
« Reply #4 on: December 06, 2010, 12:14:00 AM »
Just my color combination. White on top of the cowl. I read that down in the wiper arm recess was supposed to be painted black, but many were not.  I did mine black. This may only apply to Z/28 since that is what Mark was responding to
 in this thread:
http://www.camaros.net/forums/showthread.php?t=75096&highlight=cowl+color
Gary
« Reply #5 on: January 13, 2011, 04:43:23 PM »
Norwood 04C survivor 46k miles  VIN 633599
Textured dash paint applied AFTER striping..
Angle of white paint spray through the mounting and washer nozzle hole
srode
« Reply #6 on: January 14, 2011, 02:22:09 AM »
Thanks for the pictures, very helpful to see the spray pattern - This was for a black car with white stripes,  right?  Assume a Z28?
« Reply #7 on: January 14, 2011, 03:22:35 AM »
Orig paint.
srode
« Reply #8 on: January 14, 2011, 10:37:28 AM »
Seems like the black / white combo the lwer section is almost an overspray where the pace car its more uniform inside the lower cowl section - I'm guessing since there's not reall standard other than perhaps a maturing approach to masking off what wasn't painted as the cars move forward in time, you could expect to see quite a bit of varitatino from car to car.  I'll show the pictues to the shop doing my paint work, very helpful guys, much appreciated.
« Reply #9 on: January 17, 2011, 04:11:54 PM »
Yes black with white stripe X33.
The early cars had much more overspray on the cowls and down the firewall.
There is one in Jerry's book which has nearly a white firewall.
Here is a 10D being restored which has the correct replicated heavy overspray pattern.
Completed Firewall
« Reply #10 on: May 19, 2012, 11:30:38 PM »
04C Z10 original paint...
