Author Topic: 69 Z28 Camaro rear brake drums?  (Read 5173 times)
rally
« on: December 02, 2010, 07:29:49 PM »
Guys what style rear brake drum did Chevy use on the 69 Z28? Was it the smooth sided drum or the finned style? Also did the factory use a balance weight on there drum along with a GM stamped code or ID? Thank You
Re: 69 Z28 Camaro rear brake drums?
« Reply #1 on: December 02, 2010, 08:25:25 PM »
Rear brake drums were non-finned; some had a balance weight, some didn't. There should be a casting number and maximum diameter cast into the O.D. of the drum.
rally
« Reply #2 on: December 02, 2010, 08:27:23 PM »
Thanks John for the info.
Jerry@CHP
« Reply #3 on: December 02, 2010, 11:37:05 PM »
Last three digits are 177,
Jerry
