Author Topic: 12 Bolt brake line T-Block on 69 Camaro Z28?  (Read 7934 times)
rally
« on: November 30, 2010, 11:01:37 PM »
Guys i am stumped here? What did Chevy do on their 69 Camaro 12 brake line T-Block? Did they use this T-Block to connect the brake lines on the 12 bolt? If so where could i purchase one? Thank You
mark x22
Re: 12 Bolt brake line T-Block on 69 Camaro Z28?
« Reply #1 on: November 30, 2010, 11:27:04 PM »
its built into the hose
« Reply #2 on: December 01, 2010, 02:22:49 AM »
Starting late in the 1968 model year, they went to the intergrated tee built into the line. My 05D (68) has it. I haven't done a lot of research on this, but it appears that late April or early May, 1968 is the changeover date.
Terry
« Reply #3 on: December 03, 2010, 09:20:43 PM »
Search rear drum brake hose for your 69, the block is attached to the hose. you will need a bracket to attach it to the rear.
