Author Topic: '67-'69 Camaro COWL PANEL  (Read 12990 times)
binky3
  • Racing and Restoration
« on: November 28, 2010, 10:25:08 PM »
'67-'69 Camaro COWL PANEL(Top Vent with Grills Panel--where windshield wipers come out)-----How do I tell an Original GM Panel from a reproduction panel??  There are no numbers I can find. The thicknesses of the 2 panel seem to be .038/.044" on the original GM panel; and .032/.039" on the reproduction panel. Probably the thicker one is the GM??  Not real sure.  Both panels look the same to me.   I need help on this one please.
Jerry@CHP
Re: '67-'69 Camaro COWL PANEL
« Reply #1 on: November 29, 2010, 12:03:43 AM »
Another FYI,
'67's are different than '68-69's.  There are little ribs on the '68-69's where the 90 degree bend is.
Jerry
BlackoutSteve
« Reply #2 on: November 29, 2010, 12:40:23 AM »
67s have a round wiper-motor hole also. 68-69s are oval.
Charley
« Reply #3 on: November 29, 2010, 03:39:58 PM »
binky...Last time I checked you could still buy them from Chevrolet. Try checking at gmpartsdirect.com or your Chevy dealer.
binky3
« Reply #4 on: November 29, 2010, 04:09:43 PM »
Thank you all for your help and replies. But I'm still kinda unclear about an Orig. GM cowl panel vs. a reproduction panel. Are all the lines the same??   Does the reproduction panel have 'smoother' lines and not 'so defined' corners??   Are the 'ribs', probably stamping die marks I think, only common to the Orig. GM panel??
Jerry@CHP
« Reply #5 on: November 29, 2010, 05:47:14 PM »
Two reinforcement ribs close to the out cowl screw holes on each side where the 1/4" "E" head screws fasten to mount the cowl panel down.  Must be a 1968 mid year introduction as my early 11E build white '68 Z28 does not have them.  My 03A car does.  The Strickler does does have them, 04A build.
Find a good used one that matches the correctnes of the build date of your car.  That is what I would do.  They are out there.
Good luck,
Jerry
Charley
« Reply #6 on: November 29, 2010, 06:25:11 PM »
What year are you looking for ? If a 69 just get the real GM one. You can probably find used at swap meets for 20.00 or at GMpartsdirect.com they are  GM PART # 3891610
PACK QTY: 1    CORE CHARGE: $0.00
GM LIST: $255.02
OUR PRICE: $153.47
DESCRIPTION: COWL GRILLE PANEL
I think blackout Steve is talking about the upper part of the firewall that has the hole for wiper motor.
binky3
« Reply #7 on: November 29, 2010, 06:54:53 PM »
Thank you Jerry---Merv.  I've got to post about header panels, but that's later(allot the same questions).
Charley
« Reply #8 on: November 29, 2010, 10:44:18 PM »
Here are pics The ribbed one is on a 69 and the non rib is on a 67
binky3
« Reply #9 on: November 29, 2010, 11:48:43 PM »
On the blue cowl panel--the triangular piece that is sticking out??
Charley
« Reply #10 on: November 30, 2010, 12:16:41 AM »
yes
binky3
« Reply #11 on: November 30, 2010, 12:28:05 AM »
Thanks, boy was that simple.  Now about Original Header panels('67-'69). The '67 and the '68 seem to be the same. The '69 has more of a "V" shape to it. What are the differences on an orig. GM panel and a reproduction panel?? Can you help on this subject??
Merv.
Jerry@CHP
« Reply #12 on: November 30, 2010, 12:53:15 AM »
Charley,
Thanks for posting the photos.  A picture is worth a 1000 words.
Jerry
Jerry@CHP
« Reply #13 on: November 30, 2010, 12:54:49 AM »
Good project for CRG, find out what month that cowl panel transition was during the '68 model year.
Jerry
« Reply #14 on: November 30, 2010, 03:02:50 AM »
Jerry
Great idea.  My 02C Van Nuys built '68 Z/28 has the ribs on the cowl panel.
