Author Topic: 10 bolt parts on a 12 bolt?  (Read 11277 times)
mopar346
« on: November 27, 2010, 10:46:19 PM »
Picked up a 67 posi 12 bolt today at the Turkey Rod Run with no axles or brake backing plates. I believe the brakes and backing plates will fit, but what about the axles?? The only reason I ask, is I remember something about 10 bolt tubes being the same as 12 bolt tubes.
Thanks in advance, Kevin
rodent
Re: 10 bolt parts on a 12 bolt?
« Reply #1 on: November 27, 2010, 10:56:02 PM »
EDIT: info I posted was incorrect
The 10 bolt ones will fit :) just went outside and looked and it was the full size 12 bolt that I was thinking of :( my mistake
« Last Edit: November 27, 2010, 11:24:26 PM by rodent »
mopar346
« Reply #2 on: November 27, 2010, 11:01:01 PM »
Thank you, I thought they were the same. Any thoughts on a donor other than the proper 12 bolt backing plates?
rodent
« Reply #3 on: November 27, 2010, 11:17:10 PM »
EDIT: My mistake, the 10 bolt brakes will fit.
My apologies for the miss information, it was full size 12 bolts that i was thinking of :(
mopar346
« Reply #4 on: November 27, 2010, 11:33:42 PM »
Very cool so the brakes are the same as I thought. Now if someone knows about the axles I'll be set, picked it up for a song.
mark x22
« Reply #5 on: November 28, 2010, 12:05:24 AM »
10 bolt is 28 spline , 12 bolt is 30 spline
mopar346
« Reply #6 on: November 28, 2010, 01:06:05 AM »
Thanks, but Nova 12 bolt axles would be the same, correct?
mark x22
« Reply #7 on: November 28, 2010, 01:30:07 AM »
mopar346
« Reply #8 on: November 28, 2010, 02:49:43 AM »
Yep, not a bad option.
