Author Topic: 1968 camaro washer pump  (Read 4453 times)
68rs327conv
    • The build
« on: November 25, 2010, 03:02:33 AM »
Any trick to removing the cam lobe under the washer pump? Service manual says it is press fit.  I want to use the early design washer pump on my 68 wiper motor but it has the plastic cam lobe (which is slightly larger) and I picked up a early set up with the steel cam lobe.  I am trying to avoid breaking it
68 RS Conv 327/210hp, Powerglide Factory AC
68rs327conv
    • The build
Re: 1968 camaro washer pump
« Reply #1 on: November 25, 2010, 06:01:12 PM »
Never mind, got it off
