Author Topic: 68 4-speed saginaw reverse light switch  (Read 11751 times)
brad68RS
« on: November 24, 2010, 05:23:15 PM »
Does anyone know what switch was used on a 4-speed Saginaw transmission? I have a 68 Saginaw transmission, but not sure it has the right side cover. Please help and if you have a picture that is even better. Thanks, Brad
Re: 68 4-speed saginaw reverse light switch
« Reply #1 on: November 25, 2010, 04:49:18 PM »
The Saginaw and Muncie used the same switch, with a different bracket to attach it to the side cover bolts. See your Assembly Manual, section M20, sheet A7, View "A".
JoeC
« Reply #2 on: November 27, 2010, 10:03:09 AM »
the switch rod may be different also since Muncie and Saganaw has different location of the rev trans arm
brad68RS
« Reply #3 on: November 30, 2010, 08:01:39 PM »
Thanks John, now If I could find the 2 switches I would be happy, but the impossible search continues
« Reply #4 on: December 01, 2010, 06:47:12 PM »
All of the usual suppliers have the switch, but the Saginaw mounting bracket may be more difficult to find. Try NPD, Classic, Firewheel, Ground Up, etc.
brad68RS
« Reply #5 on: December 01, 2010, 07:08:08 PM »
Thanks John, I am continuing the search. Seems like the high performance cars are easier to find parts for and they made a lot more of the standard cars like I have. Question.... I have a 68RS with a 327/275 with a 12 bolt rear end. ALL of the numbers match, but the trans is a Muncie (non-matching) Did they ever use a munice on this car? The transmission I have is a 68 camaro transmission, but not the correct serial # for my car.
« Reply #6 on: December 02, 2010, 12:54:55 AM »
Nope, the L30 only came with a Saginaw. http://www.camaros.org/l30m20.shtml#L30
« Reply #7 on: December 04, 2010, 03:51:14 AM »
What is the # on the trans?  Post in orphans.
brad68RS
« Reply #8 on: December 06, 2010, 03:01:48 AM »
68Z, I will post the Muncie I have in Orphans after I take the car apart to restore it. Right now it is a street car. But it is not chopped up. I will have to write the number down and post it at that time.
« Reply #9 on: December 07, 2010, 01:54:06 AM »
Sounds good.  I'm always on the lookout for my engine and if the car's around, someone might like to have that tranny when you're ready.
brad68RS
« Reply #10 on: December 07, 2010, 04:29:16 PM »
FYI to all. The switch bracket on my car is the right bracket for the saginaw. It has 2 sets of holes that fit the saginaw and the muncie. After viewing the picture Boston14 sent me I inspected the car I have at home and it has the same bracket, but it is mounted to the Muncie that is in the car. The car is a L30 M20 car and originally had a saginaw. I am going to have a fabricator that does quite a bit of work for me at my business fabricate some of these if anyone else needs any I will have them. Thanks Boston14 for the pictures! It has helped me solve my puzzle.
