Author Topic: 1969 Voltage Reg. Mounting.  (Read 10804 times)
69z28302
« on: November 13, 2010, 06:05:39 PM »
I'm sure this has been covered but I cant find anything on it. I have a 69 02D build date Norwood car . Does it mount with screws or screws and rubber nuts?
Thanks CRG
« Last Edit: November 13, 2010, 07:12:59 PM by 69z28302 »
BlackoutSteve
Re: 1969 Voltage Reg. Mounting.
« Reply #1 on: November 13, 2010, 10:51:09 PM »
69s are mounted directly to the radiator support using 3 tapping screws shown in UPC6-B7. Screws are GM# 177999 and are available through AMK as B-12096 (phosphate) or B11094 (zinc) $3 buys 6.
Can someone confirm which finish is correct please.  :)
67-68s used rubber well-nuts with machine screws to insulate from vibration and used a ground wire to the support.
69z28302
« Reply #2 on: November 14, 2010, 12:01:37 AM »
Great, Already got the AMK kit. I was confused about this after a Camaro parts website list the rubber insulators for 67~69 for the voltage regulator.
BlackoutSteve
« Reply #3 on: November 14, 2010, 12:19:25 AM »
So typical. Probably the same site that list the correct 67-69 Caution Fan decal.
Never believe a parts catalog.
BTW, what is the finish of the reg screws in the AMK kit?
69z28302
« Reply #4 on: November 14, 2010, 12:27:59 PM »
These are zinc. Don't know if thats correct though.
Stingr69
« Reply #5 on: November 14, 2010, 04:03:50 PM »
I believe early '69 cars used the rubber well nuts. Later cars used sheet metal screws.
-Mark.
red69
« Reply #6 on: November 14, 2010, 04:19:50 PM »
I can't look at the car right now, but, I believe my 12C VN car has insulators
Steve Shauger
    • Vintage Certification
« Reply #7 on: November 14, 2010, 04:28:16 PM »
The norwood cars I have inspected from early cars; 9B of 68 to 10A of 69 have used only sheetmetal screws. All examples were survivor cars which have been Vintage Certified.
Steve Shauger
Stingr69
« Reply #8 on: November 14, 2010, 04:32:01 PM »
My 10A Norwood car had the holes for rubber well nuts. That might be close to a cut off?
-Mark.
Steve Shauger
« Reply #9 on: November 14, 2010, 05:41:54 PM »
-Mark.
I assume you mean of 10A of 69 just for clarification.
Steve Shauger
« Reply #10 on: November 14, 2010, 09:25:32 PM »
My unmolested/original 02D '69 has sheet metal screws (no rubber well-nuts), as shown in the Assembly Manual.
69z28302
« Reply #11 on: November 14, 2010, 10:59:55 PM »
Thanks John, what are the finish on them please?
Boston14
« Reply #12 on: November 15, 2010, 04:49:15 AM »
My 'early' 11D Norwood '69 car has sheet metal screws also.  Can't say for sure on the finish, (perhaps zinc) the bolts have seen better days.
boston14
boston14
1969 SS/RS 350 Convertible
Stingr69
« Reply #13 on: November 15, 2010, 03:43:35 PM »
-Mark.
10A '68 for '69 production year.
« Reply #14 on: November 15, 2010, 04:21:28 PM »
They're zinc-plated; phosphated screws weren't used for grounding applications.
