Author Topic: D80 Rear Spoiler Dealer Install?  (Read 29054 times)
Re: D80 Rear Spoiler Dealer Install?
« Reply #15 on: November 12, 2010, 04:30:01 AM »
Those rods look equal to me = not a D80 car.
Date is on the center rib of the lid.
IZRSSS
  • Guest
« Reply #16 on: November 12, 2010, 01:09:26 PM »
I agree, the torsion bars look identical. It doesn't surprise me that it isn't a D80 car. If you recall J also mentioned it is a strip delete car. These two discoveries are consistant with a conservative look. I think this also raises a red flag on the front spoiler. It does not have the main frame anchor point.
The other dilemma I'm up against is the hood, its a repop. Was it possible to order a plain hood on a SS car? If it was I think Pat would have opted for this as well. Nothing on the car is consistant with what a guy would have ordered.
I could not find a stamp on the center rib/ribs of the lid. The paint was laid on pretty thick so maybe it's just covered up. Other than the stamp is there any other way to determine if its factory? Are all 1st gen lids interchangeable?
Just trying to piece these last few items together as best I can. Its been tough without the build sheet.
Thanks Kurt
« Last Edit: November 12, 2010, 01:28:19 PM by IZRSSS »
Gramps69Z
  • 69 X33 D80
« Reply #17 on: November 12, 2010, 04:45:51 PM »
Here's a picture of the rods on my D80 car.
Captain John Wykoff
« Reply #18 on: November 12, 2010, 04:56:42 PM »
The blue lid in the photo is the '69 "second design" lid - same one that's on my car; has the four holes in the inner panel to clear the attaching studs for the Firebird spoiler. Photo below is mine - the Fisher "run number" (date code) is directly below the jack instruction sticker, on the raised rib; you can't read it in the photo, but you can see it if you look closely. They moved it on the later 3rd design lid.
IZRSSS
  • Guest
« Reply #19 on: November 12, 2010, 05:07:51 PM »
There is obviously a visual distinction between the two. It certainly looks like the torsion rods are original to the car. If you look close, the spatter paint line would be hard to duplicate. No rear spoiler...what was this girl thinking ???!
Thanks for the pic John
« Last Edit: November 12, 2010, 05:26:01 PM by IZRSSS »
IZRSSS
  • Guest
« Reply #20 on: November 12, 2010, 05:14:39 PM »
I see it on my lid now... unfortunately there is so much paint that the stamp looks like a blur. I didn't know there were three different designs, thanks! Can you tell me which of the three is correct for a 12A Van Nuys build? Not sure if it really matters where it was built...?
Thanks John
« Reply #21 on: November 13, 2010, 04:26:15 PM »
Thanks John
It appears that the 2nd-design deck lid was used between about November '68 to April '69.
IZRSSS
  • Guest
« Reply #22 on: November 13, 2010, 04:52:40 PM »
Thanks again John. That's what I was hoping to here.
Dave69x33
« Reply #23 on: November 17, 2010, 03:18:40 AM »
My 1969 05A Norwood Camaro appears to have the 2nd design (with the four holes in the inner panel). The inner panel is stamped "T A10" in raised rib, to right of the jack instructions, and "A10" in a second spot along the middle bottom of the raised rib.
If I recall correctly, the T is the stamping plant, and stamping plant codes are typically H, K and T.  Has it been determined which plants these codes stood for?
The “A10” stands for the 10th week of 1969 which would be the week of March 10th, correct?
« Reply #24 on: November 17, 2010, 04:26:46 PM »
That's the "third design" deck lid (date code relocated, no weld tabs on the rear hem flange); it was used from about March to the end of the model year. I don't think the plant codes have been decoded, except for Kalamazoo ("K").
Dave69x33
« Reply #25 on: November 18, 2010, 01:24:51 AM »
And what does the "A" stand for in "T A10"?
L78 steve
« Reply #26 on: November 19, 2010, 02:22:10 PM »
   Weld tabs?
69 Z/28 Dover White. SOLD
« Reply #27 on: November 19, 2010, 04:28:27 PM »
<<Weld tabs?>>
Yes - see photo below; the second design '69 deck lid had eight of them across the rear edge.
L78 steve
« Reply #28 on: November 29, 2010, 06:16:26 PM »
Does anyone know how to decode the dates? My trunk lid has a T  A44.
mark x22
« Reply #29 on: November 29, 2010, 11:19:38 PM »
forty fourth week
