Author Topic: Power steer pump cap  (Read 84358 times)
x77-69z28
Re: Power steer pump cap
« Reply #60 on: January 29, 2007, 03:03:16 PM »
when i bought my 05A x77 car in 1977, it had 31,000 miles on it and it has the black plastic cap. i dont know what happened in the first eight years, but i would assume with 31,000 miles, that it would be original.
great thread
My68SS
« Reply #61 on: January 29, 2007, 03:41:42 PM »
I had know idea that what I thought would be a routine question, would blow out to a 4 page discussion!   :o   :)
The inoccent 68 power steer cap has stirred up a hornets nest of controversy and parts book searching!
The joy of trying to unravel the mystifying past   :P
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
cfar
  • L30/M35 Tuxedo Black
« Reply #62 on: January 30, 2007, 01:33:10 AM »
I just checked the P/S cap on my 02C built '68 Z/28. Here's what I have:
- metal cap (appears to have been originally painted black - most of this black paint is worn off).
- the words "USE AUTOMATIC TRANS FLUID TYPE A - CHECK OIL HOT".
- short (44 mm) black plastic tube (stick).
- "FULL" line on tube (stick) is 20 mm from the bottom of tube (stick).
- cap is vented on the top of the cap through the tube (stick).
- cap is a little loose on the P/S pump housing when it reaches the stops. OK it you back it off very slightly. worn gasket?
- I'm not 100% positive this is the original cap.
Hope this info helps.
That is the same cap on my 11C 68 LA car which I also know is correct and original.
Every 69 in my shop now (3) have a black plastic cap-2 sb -11c and 09a one bb 07b.
My 69 El Camino sb 07c  has a plastic cap also.
I think we have a winner-Black plastic.
Frank
11C 1967 - Born on date estimated Nov 15th,1967 LA Plant
In Service Jan 18th, 1968  Hollywood CA
Pacecarjeff
    • pacecarjeff.com
« Reply #63 on: January 30, 2007, 03:34:02 PM »
I did finally change the PS cap on my 69 - 03D Z11 to a plastic.
However, I left the metal one in the trunk, just in case. :)
« Reply #64 on: January 30, 2007, 07:18:53 PM »
Hi Frank -
   Thanks for confirming your P/S cap is the same (and original) as mine. I'm going to declare my cap to be original also. It too is a Los Angeles car.
Dave69x33
« Reply #65 on: February 01, 2007, 02:14:23 AM »
For what its worth, my 05A, Norwood 69Z had just over 45K miles before the restoration.  I can not be 100% sure but my PS pump appears to be original to my car and it has a metal cap.
Pacecarjeff
    • pacecarjeff.com
« Reply #66 on: February 01, 2007, 02:32:41 AM »
That is why I kept the metal one in the trunk, just in case. ::)
Acording to the 5 pages of discussion here in this thread.
That is not the original cap for your car - Or is it? ???
x77-69z28
« Reply #67 on: February 01, 2007, 10:06:51 PM »
dave, we should get together and compare notes on our cars, as they were built the same week!
Jerry@CHP
« Reply #68 on: February 02, 2007, 02:31:56 PM »
Even in the concours judging, we want to see a natural cap on 67 and 68 and black on the 69s.
Jerry
Pacecarjeff
    • pacecarjeff.com
« Reply #69 on: February 04, 2007, 05:21:25 AM »
Jerry
Is the PS cap metal or plastic for 1969?
The Corvettes changed to the plastic cap in mid April 1969- were the Camaros the same?
cfar
« Reply #70 on: February 05, 2007, 04:07:18 AM »
I am corrected from my prior post of possible overspray on my cap. :-[
Jerry is right  ;D
My cap is natural-the black was old grim and the under side shows no signs of ever being painted-now (that I have it apart to reseal it).
On another post I checked the pump numbers which are correct also and un restored or replaced since new like the cap.
Jerry
RS/SS4speed
« Reply #71 on: March 05, 2007, 06:53:16 AM »
For what its worth, i have a sept. 68 LA car 09B .L5014XX It has the plastic cap. All org. drivetrain when found.
DT
« Reply #72 on: November 16, 2014, 06:15:51 PM »
OK, I know this is an OLD thread!   What was the outcome here for a 69 cap???   Metal or Plastic???
Donny
« Reply #73 on: November 16, 2014, 07:37:09 PM »
I, personally, have never seen a 69 CAMARO with an original metal cap. I have seen metal caps on 69 other models. I will stick out my neck and declare plastic for 69 F bodys based on many observations.
« Reply #74 on: November 17, 2014, 09:02:32 PM »
Agreed.
