Author Topic: Power steer pump cap  (Read 84372 times)
Pacecarjeff
    • pacecarjeff.com
Re: Power steer pump cap
« Reply #15 on: May 15, 2006, 07:47:17 PM »
This one looks like it was partialy painted:
« Last Edit: May 15, 2006, 11:50:28 PM by Pacecarjeff »
Pacecarjeff
    • pacecarjeff.com
« Reply #16 on: May 15, 2006, 07:48:11 PM »
These were both natural - not removed from Camaros.
« Last Edit: May 15, 2006, 11:47:59 PM by Pacecarjeff »
My68SS
« Reply #17 on: May 16, 2006, 02:16:25 AM »
This nos one looks correct unpainted from the manufacturer, quoted as grp 6.635  pn 5690846 for a variety of chevy's including 67-69 Camaro and 63-69 Corvette.
Of course, what happened on the assy line with regard to paint or no paint is another story. Perhaps the pump assembling was outsourced to a couple of places with one paintng the cap and the other not?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
My68SS
« Reply #18 on: May 16, 2006, 02:18:43 AM »
hmmm....then there's the different colored plastic of the level indicator...
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
Pacecarjeff
    • pacecarjeff.com
« Reply #19 on: May 16, 2006, 04:03:13 AM »
That is the first short one I have seen with the white plastic stick.
Usually the ones for the taller pumps have had that color stick. Interesting.
« Reply #20 on: May 17, 2006, 04:46:24 AM »
I have seen a few unpainted caps. Not common (IMO) and they stand out.
Every 69 cap I've seen has been plastic (also via junkyarding). :) There also different lengths of the stick on the cap. Didn't realize that til recently....
lakeholme
  • 68-12D L30/M35
« Reply #21 on: May 17, 2006, 02:01:03 PM »
All the way back to the original question:  I think, 5690846 for a 68... But it would be great if Ed or someone could verify.
My68SS
« Reply #22 on: May 17, 2006, 03:52:18 PM »
Quote
Are the different lengths you note just for 69's? Are there just two different lengths and do you know what the lengths are?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
Pacecarjeff
    • pacecarjeff.com
« Reply #23 on: May 17, 2006, 08:39:56 PM »
According to NCRS. The metal cap was used through mid 1969.
After late June or so - they went to the plastic caps.
NCRS is usually right on with this stuff. I have to believe that the Camaro was exactly the same.
The longer stick was used for the taller pumps used in the full size cars.
rich69rs
  • LF7/M35/Z22/Z87
« Reply #24 on: May 17, 2006, 08:48:10 PM »
Mine is black and plastic.  Assume it is original to the car - but no way of knowing for sure.  I don't remember ever seeing a metal cap on a '69.  Then again, i've slept since yesterday as well.
« Last Edit: May 17, 2006, 08:58:09 PM by rich69rs »
Richard Thomas
1969 RS
Pacecarjeff
    • pacecarjeff.com
« Reply #25 on: May 17, 2006, 08:54:16 PM »
Maybe they started using the plastic cap earlier on the Camaro.
I don't really know.  ???
But, whenever I saw a plastic cap on a 69, I always just assumed it was replaced.
I guess I could have grabbed a bunch of those over the years. :(
KevinW
« Reply #26 on: May 18, 2006, 05:26:43 PM »
I have an original oct (68) 69 with the original black plastic cap.
Pacecarjeff
    • pacecarjeff.com
« Reply #27 on: May 18, 2006, 05:42:59 PM »
So then are we saying that the Camaros originally came with a plastic PS cap in 69?
Are we sure? That would mean the Corvettes are different. ???
Does anyone have a picture of the exact writing on the top of an original 1969 plastic cap?
What would make the old one different then the current cap available from GM now?
« Last Edit: May 18, 2006, 05:44:33 PM by Pacecarjeff »
rich69rs
  • LF7/M35/Z22/Z87
« Reply #28 on: May 18, 2006, 06:13:30 PM »
Not the best picture as this is cropped and enlarged from a picture of my engine prior to rebuild in 2005.
Wording says (corrected as per JohnZ noted):
"Use Approved Fluid"
"FIll to Proper Level"
This cap has always been with the car since I purchased it in Nov 1991.  I assume it is original to the car, but I have no way of knowing for sure.
« Last Edit: May 18, 2006, 07:39:50 PM by rich69rs »
Richard Thomas
1969 RS
« Reply #29 on: May 18, 2006, 06:42:31 PM »
Exactly the same cap and wording as my 02D '69 - as in the photo above, it says "Use Approved Fluid", not "Use Proper Fluid".
« Last Edit: May 18, 2006, 06:44:22 PM by JohnZ »
