Author Topic: Correct Window Molding clips  (Read 7105 times)
MyRed67
  • SZZLN 67
« on: November 03, 2010, 07:31:40 PM »
  I have an early build (11A - 66) '67 Coupe no Vinyl Roof.  I am trying to find out what are the "correct" Windshield side and upper molding clips.  Also "correct" Rear Window molding clips.  Anybody have part #'s ?   I'm seeing different ones offered, and they don't coorespond with what is on the car.  Maybe they have been changed.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
jeff g
Re: Correct Window Molding clips
« Reply #1 on: November 10, 2010, 02:27:01 AM »
Front windshield clips are RED Oxide, rear are either a"Gun Metal" Color or Black any of the parts houses have them .Yours were probably changed at some point or the originals rusted away and were change with what ever was available
MyRed67
  • SZZLN 67
« Reply #2 on: November 10, 2010, 06:43:35 AM »
jeff g>  Would these be the correct clips?   Longer Reddish - Front, Narrower Gray - Rear??
1967 Camaro  LOS  11A
jeff g
« Reply #3 on: November 10, 2010, 01:44:04 PM »
Yes, make sure that you check that ALL MOUNTING PINS are in tact, if not have the WELD in type installed. I would not recommend the screw in type replacement as they will fail. The weld in type are easy to install check with your local body shop they should have a Stud/Dent puller   Welding gun that can weld them in no time. the studs  usually come with this tool  and are forgotten about as they are not used as much on Modern cars anymore. There should a BAG of them in the case that the tool comes in Very SMALL  Pin studs.
MyRed67
  • SZZLN 67
« Reply #4 on: November 12, 2010, 05:01:52 AM »
Thanks!!! jeff
1967 Camaro  LOS  11A
flyingskibiker
« Reply #5 on: January 23, 2012, 12:05:17 AM »
tmodel66
« Reply #6 on: January 23, 2012, 12:37:17 AM »
Yep That's them.
flyingskibiker
« Reply #7 on: January 23, 2012, 12:50:39 AM »
Thanks, Daniel.
The ones that are currently on there are the ones like the upper windshield clips that have the side to side slot (first pic in thread above).  I broke out a package of rear clips that I bought years ago since a few of the ones on the car were broken.  They didn't match, of course...  I figured I yet again had bought something before the "correct" ones were available.  Now, I know.
Thanks again!
« Reply #8 on: February 06, 2012, 04:56:13 PM »
There is a discussion on the Nova Research Group regarding the different clips.
Here are my originals...
