Author Topic: tag seem correct?  (Read 18280 times)
harddock
tag seem correct?
« on: October 25, 2010, 05:21:31 PM »
1968 Camaro  vin 124378N438140
Cowl 5B     NOR 130556
712  AA
Car is black V8 with Std int. Not sure if cowl tag is repo and can't post picture right now
tom
    • Discount Internet Services
Re: tag seem correct?
« Reply #1 on: October 25, 2010, 06:40:33 PM »
When you can post the pucture. You will find out if it is original or fake.
69 X11 Z21 L14 glide
o
harddock
« Reply #2 on: October 25, 2010, 08:56:30 PM »
When I get the car, I am more concerned with the info being correct
« Reply #3 on: October 26, 2010, 05:10:27 PM »
You can decode the cowl tag yourself on the CRG main site, here:
http://www.camaros.org/numbers.shtml
« Reply #4 on: October 26, 2010, 06:09:09 PM »
Quote
Quote
However, I'm always leary of late cars with AA paint. Post a picture and we can tell you more.
harddock
« Reply #5 on: October 28, 2010, 03:15:59 PM »
I am mainly looking to see if the VIN, Body number and date code seem to line up.
« Reply #6 on: October 30, 2010, 02:39:40 AM »
Those are 2 different questions. Without a pic, I can't comment on the originality of the tag.
But the #'s do not line up.
harddock
« Reply #7 on: October 31, 2010, 04:00:15 PM »
Why do you say the numers are wrong?
« Reply #8 on: October 31, 2010, 08:08:22 PM »
Because that VIN doesn't go with that tag.
« Reply #9 on: October 31, 2010, 09:40:13 PM »
To elaborate on what Kurt said, your trim tag indicates your car was built the second week of May, 1968 (05B), however, your VIN indicates the car was built the third week of May, 1968 (05C), therefore one or the other has been swapped.
I would imagine it's the trim tag, but check the hidden VIN to make sure it matches the VIN on the dash, and post a picture of the trim tag.
harddock
« Reply #10 on: October 31, 2010, 11:29:42 PM »
When I take May total production (39952) and divide by working days (22) I get 1816 cars per day. My serial # puts the car and a build of May 6 or 7 which would be week 2 not 3 or am I figuring wrong. How did you determin third week of May?  I am trying to get hold of the cowl tag but I'm not sure the PO still has it. It was taken off the car.
« Reply #11 on: November 01, 2010, 04:01:08 AM »
Look closer at that production data (http://www.camaros.org/geninfo.shtml#HowMany). "The data for some months (especially May and June 68 at Norwood) deviate significantly from actual build dates, while other months correlate well.
We have data on cars close to your VIN and they are not 05B.
harddock
« Reply #12 on: November 01, 2010, 11:09:45 AM »
It did seem odd that there was such a jump in May numbers. I had used figures from another site and came up with a 13th build date but thinkng the CRG numbers to be more accurate I used their numbers for my calculation.
harddock
« Reply #13 on: November 01, 2010, 02:46:43 PM »
If this is correct then all that is wrong is the 5B is being mistaken for a 5C?
« Reply #14 on: November 01, 2010, 03:17:39 PM »
Norwood production was 912 cars per day.
