Author Topic: tmodel66 '69 Project  (Read 17510 times)
IZRSSS
  • Guest
Re: tmodel66 '69 Project
« Reply #15 on: October 26, 2010, 04:04:02 AM »
Old pic of Daniel loading his '69 SS onto a trailer to begin restoration...
Boston14
« Reply #16 on: October 26, 2010, 11:01:32 AM »
My car, which I bought from the original owner back in 1975 is an 11D build so it has no X codes.  The camera I used for those pictures is a Nikon CoolPix 8700.
boston14
boston14
1969 SS/RS 350 Convertible
IZRSSS
  • Guest
« Reply #17 on: October 26, 2010, 03:32:16 PM »
According to AIM, M38...A8,A9 & A10, the Trans-Detent Cable is the same for both the L-6 & the V8. The only difference is the site/ location of the mounting clip.  As for the pics of your cable, its spot-on.
IZRSSS
  • Guest
« Reply #18 on: October 26, 2010, 07:03:57 PM »
L48 Carter Quadrajet 4MV...ID# 7029202 DH which I cross referenced with KurtS; 1969 Carburetor Usage chart (Automatic).
Manual; ID#7029203 DY
« Last Edit: October 26, 2010, 08:32:21 PM by IZRSSS »
IZRSSS
  • Guest
« Reply #19 on: October 26, 2010, 07:07:10 PM »
'69 L48 Quadrajet Cont'd...
IZRSSS
  • Guest
« Reply #20 on: October 26, 2010, 08:56:40 PM »
boston14
My car is a 12A build w/o X Codes as well.  Not really sure why that is but KurtS gives a detailed explanation on the main page. You can find it under Numbers Decode; #9 (1969 Cowl Tag-X Codes).
Not really sure how you post links off of the main pg?
IZRSSS
  • Guest
« Reply #21 on: October 27, 2010, 09:14:11 PM »
I've been red-flagged...does anyone have a pic of a QJet with the correct Vacuum Advance Hose/Line?
IZRSSS
  • Guest
« Reply #22 on: October 28, 2010, 11:10:36 PM »
Error...wrong site...sorry :-[
KurtS doesn't have a bail format for PC dummies...
IZRSSS
  • Guest
« Reply #23 on: November 01, 2010, 08:41:14 PM »
Just received a few pics from Daniel...They show the car in its current stage. Hope you can make them out.
He started his project on June 6, 2010
Thanks Dan
bc69
« Reply #24 on: January 10, 2012, 03:47:40 AM »
where can i get the bracket like is use in above kickdown cable. This mounts the cable low like old style so vac hose can pass through bracket?
Brad
RSSS
IZRSSS
  • Guest
« Reply #25 on: January 10, 2012, 04:04:53 AM »
PM sent...
