Author Topic: Bracket on Evaporator Housing?  (Read 8334 times)
69-er
« on: October 09, 2010, 01:58:28 PM »
Would someone possibly know what this bracket is for that is riveted to the housing next to the expansion valve? I can't remember if I ever saw anything attached to it. All my pre dis-assembly pictures show it to be unused.
Also, is there anything that keeps the coiled copper lines on the expansion valve from vibrating? They are pretty flimsy. They are just hanging out in the middle of nowhere. I haven't seen any pictures that show what would hold them.
mark x22
Re: Bracket on Evaporator Housing?
« Reply #1 on: October 09, 2010, 04:06:26 PM »
A clamp goes around the expansion valve and screws to that hole .
69-er
« Reply #2 on: October 10, 2010, 05:49:41 AM »
That's what I figured too, but the bracket is lined up to the port on the valve.  If it was a little lower, a clamp would work quite well.  I can't visualize how a clamp could wrap around the valve in my situation.  I don't have any reason to believe the valve is in the wrong location.  The tubes coming out the evaporator all seem to be properly positioned.
IZRSSS
  • Guest
« Reply #3 on: October 10, 2010, 12:51:24 PM »
Would this help?
mark x22
« Reply #4 on: October 10, 2010, 01:09:26 PM »
69-er is yours small or big block ? You have one tab IZRSSS has two .
IZRSSS
  • Guest
« Reply #5 on: October 10, 2010, 01:47:27 PM »
Mark, what is the 2nd tab for?
mark x22
« Reply #6 on: October 10, 2010, 02:00:39 PM »
I think it might be used as a stop for the outlet on the expansion valve to set against . Maybe if others can look at there cars and see . My small block is like yours and my big block is like 69-er picture
IZRSSS
  • Guest
« Reply #7 on: October 10, 2010, 02:07:50 PM »
Thanks Mark, when I have time I'll check it out on the Assembly Manual.
IZRSSS
  • Guest
« Reply #8 on: October 10, 2010, 03:25:37 PM »
Nothing in AIM on either tab...
« Reply #9 on: October 10, 2010, 05:07:36 PM »
That's because it was part of the evaporator assembly as received from Harrison.
IZRSSS
  • Guest
« Reply #10 on: October 10, 2010, 08:31:02 PM »
So, do you know what the other tab is for?
