Author Topic: 4 spd shifter hole for a 69  (Read 7419 times)
x66 714
« on: October 07, 2010, 09:49:35 PM »
I have a piece of a floor that I cut out a 67 or 68 years ago. I don't remember if it was automatic or std from the 67 or not. My question is how close could it be for use on a 69? Was the hole always in the same spot for 3spd/ 4spd trouugh out the 67/69?
Thanks, Joe
mark x22
Re: 4 spd shifter hole for a 69
« Reply #1 on: October 08, 2010, 12:34:43 AM »
I think 1969 is different than 1967 /68 .
Kelley W King
« Reply #2 on: October 08, 2010, 11:40:08 AM »
When my 69 was redone the guy had a 68 Hurst shifter he located the hole with. I later got a 69 shifter and installed it. It would not go into 2nd or 4th until I reworked the floor to move the the hole back.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
big iron
« Reply #3 on: October 08, 2010, 02:20:17 PM »
Just dug out a reinforcing plate for a 67 and the front to rear hole spacing is 5 1/2" (5.500) and side to side is 4 3/8" (4.375), so the 69 is longer 1" (1.00) and narrower (1.065). I based these numbers using markx22's post.
Figuring that the spacing from the "V shaped crease in the floor" to he forward mounting hole is the same for 67-69, then that would explain the problem with the 2nd and 4th shifter problem.
Being that the 68-69 both use the same console. How did the factory get around the shifter placement difference? I would think they would have to change the placement of the consoles.
Bob
x66 714
« Reply #4 on: October 08, 2010, 03:28:28 PM »
Thanks for everybody's imput. I've forwarded the info to a guy who's replacing the entire floor pan. A problem we don't have in Tucson....Joe
mopar346
« Reply #5 on: October 09, 2010, 11:51:31 PM »
MarkX22,
Any chance of getting larger/clearer diagrams e-mailed??
Thanks, Kevin
mark x22
« Reply #6 on: October 10, 2010, 01:00:42 AM »
I tried emailing to myself and couldn't print or see any better . That's the best resolution i get as a JPEG picture . I can print clear out of the original drawing program but it loses quality converting to JPEG for photo bucket or email . I can try redrawing with bigger text which one do you need ?
mopar346
« Reply #7 on: October 10, 2010, 03:35:59 AM »
No need to go to any trouble, I actually don't have an immediate need, just collect as much documentation as I can, you never know when you might need something.
Thanks, Kevin
