Author Topic: Ignition buzzer and glove box installation  (Read 7424 times)
SS396
« on: October 04, 2010, 01:43:31 AM »
Did 68 Camaros have the ignition buzzer installed and if so was it all models. Is there any specific way to install glove box as mine wont go in. Do you have to remove the heater duct in front of console and come in from underneath?
flyingskibiker
Re: Ignition buzzer and glove box installation
« Reply #1 on: October 04, 2010, 05:31:14 AM »
The buzzer is in the voltage regulator.  So, they all came with it.  I don't recall ever seeing a different part for a VR w/o it.?.?
I'm pretty sure the glove box is put in from the back side.
Kelley W King
« Reply #2 on: October 04, 2010, 10:47:30 AM »
Where is the ignition buzzer on a 69?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #3 on: October 04, 2010, 02:37:30 PM »
It's internal to the horn relay.
« Reply #4 on: October 04, 2010, 02:47:57 PM »
Nope. It's in the horn relay.
flyingskibiker
« Reply #5 on: October 05, 2010, 02:02:06 AM »
Right.  Sorry...
Kelley W King
« Reply #6 on: October 05, 2010, 08:18:07 PM »
Does anyone know what makes the ignition buzzer work on a four speed car? I know there is a contact in the column but does it have anything to do with the clutch switch or the reverse light switch. I checked the wiring diagram in the AIM but it crosses 3 pages and is not very clear. The reverse linkage from the column to the trans is not on my four speed car due to headers and the clutch switch is evidently not connected either.On my automatic car it does work when you open the door with the key in but that car has working reverse lights and no clutch switch.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
« Reply #7 on: October 06, 2010, 03:31:01 PM »
There's no connection in that circuit to the transmission backdrive linkage or clutch switch; only from the plunger switch in the door jamb through the contacts in the ignition switch to the buzzer in the horn relay. The buzzer doesn't care what transmission is in the car or what gear it's in - onlly whether the jamb switch and ignition switch contacts are closed.
