Author Topic: Chevy orange engine paint  (Read 30153 times)
My68SS
« on: September 23, 2010, 05:26:07 PM »
Hi all,
Just wondering if there's any consensus on who makes the most 'accurate' [hue wise] chevy orange engine paint.
I've just tried some POR-15 and it looks pretty close [from old, dusty memory though :) ]. Others I've tried in the past looked a tad on the red side.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
Re: Chevy orange engine paint
« Reply #1 on: September 23, 2010, 08:16:40 PM »
POR is orange, not Chevy orange. Advanced search: http://www.camaros.org/forum/index.php?topic=5268.0
My68SS
« Reply #2 on: September 24, 2010, 02:36:07 AM »
Hi Sauron, not sure what you mean by that, they call it chevy orange, or is the hue to inaccurate - too orange??
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #3 on: September 24, 2010, 04:06:48 AM »
I tried that POR and it looked pinkish and it didn't go on well at all.  I took it all off.  It seems there are a couple of favorites but I used Aervoe and it looks right on to me.
sd1968z28
« Reply #4 on: September 24, 2010, 02:00:06 PM »
can't you still get it from gm in spray cans?
x77-69z28
« Reply #5 on: September 24, 2010, 02:30:10 PM »
i just repainted the engine in my 67 rs/ss and used seymour. according to jerry m, it is the closest to orig. EN-48 is the color code. you can order online at www.seymourpaint.com. i sound like a commercial
My68SS
« Reply #6 on: September 24, 2010, 02:48:18 PM »
That's extrodinary, how long ago did you try it? Was it rattle can or spray gun?
There's no pink cast in the stuff I got and it went on beautiful [spray gun] without filling in the casting.
Looks about the same hue as the cap on quanta's website, or the swatch on Aervoe's website
If only it was available in Au  :(
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #7 on: September 24, 2010, 04:31:06 PM »
Quanta (www.quantaproducts.com) also makes Chevy Orange that's an accurate hue and isn't quite as glossy as most of the others; very similar to Seymour Chevy Orange.
plumL78
« Reply #8 on: September 24, 2010, 04:42:10 PM »
I believe the quanta paint is seymour  and they use their owe quanta  labels
My68SS
« Reply #9 on: September 24, 2010, 06:13:14 PM »
Actually, I might be able to get the Seymour paint as they will ship internationally via fedex, who can carry this type of product.
At the moment though, their shipping/billing checkout isn't working properly so i'm still not sure of the shipping cost.
Yes, I've also noted the 'too glossy' with other products. My workaround with those was to allow 15 - 30 mins drying then mist spray to give a more satin finish.
Others have thought that as well - can anyone confirm?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #10 on: September 24, 2010, 06:20:05 PM »
You can't rely on color samples viewed on a monitor. Colors are not represented with accuracy. Quanta-Seymour correlation is in another thread on this site somewhere.  Seymour/Quanta are the recommended choices for accuracy. Or have a jobber mix it on their system. But don't pour it on and fill the casting texture; and throw some flattening agent in it to knock the gloss back.
« Reply #11 on: September 24, 2010, 06:48:54 PM »
... and isn't quite as glossy as most of the others; ....
My most common observation about engine paint is it's glossier than original. I've seen take-off parts that have been stored for years and they are not full gloss.
And as noted above, it was a quickie paint job just to get color on the engine. It was not thick and it didn't fill in / smooth out the surface.
Dave69x33
« Reply #12 on: September 29, 2010, 02:09:11 AM »
Is it recommended to use a base coat high temp primer or something similar to get a durable long lasting top coat?
Would the primer will tend to "fill-in" or soften the texture of the block and heads?
Rattle can paint tends to spray on thicker, correct?
« Reply #13 on: September 29, 2010, 04:01:41 PM »
No primer was used at the factory. I just clean the surface with lacquer thinner and shoot it.
Jerry@CHP
« Reply #14 on: October 01, 2010, 02:24:48 AM »
Seymour #EN-48.  That is the best in all the research I have done over the years.  Quantra has this packaged in their can and charges you more money for the same product.  Bottom of cans have the same codes.   That's how we knew.
Jerry
