Author Topic: Single groove L34 water pump pulley  (Read 15187 times)
My68SS
Re: Single groove L34 water pump pulley
« Reply #15 on: December 12, 2010, 04:43:54 PM »
My apologies Boston14, what you said previously is perfectly clear. I've been staring at this screen too long and are loosing the plot!!
Read Martys post upside down - early is smooth and later is ribbed.
Does anyone have a engine bay pic of a 69 bb with ps, a/c and smog?
Is that the smog pump under the alternator in Paceme's 69 pic above?
If that's so, then the single groove for bb would have found usage on 67's [different emissions standard] and 69's [different component arrangement], but as best as I can tell, not 68's, not even exports with AIR delete [if mine is anything to go by]
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
mark x22
« Reply #16 on: December 12, 2010, 06:19:28 PM »
smog pump is under the alternator .
My68SS
« Reply #17 on: December 12, 2010, 06:37:24 PM »
Cheers Mark  :)
I see it's a L34 with ps and a/c and it appears that it's still a single groove water pump pulley? The a/c and ps belts are direct to crank?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
mark x22
« Reply #18 on: December 12, 2010, 06:41:49 PM »
Yes
