Author Topic: Pressed in bumper nut  (Read 7629 times)
sixt9x33rs
« on: September 16, 2010, 11:05:02 AM »
Does anyone kow where to buy the pressed in nut that is in the fender extension of a 69 Camaro? This nut holds the front bumper to the car.
big iron
Re: Pressed in bumper nut
« Reply #1 on: September 16, 2010, 01:20:30 PM »
Had the same problem with my 67. Could not find a 3/8"-16 nut (AMK only makes up to 5/16"), so I made one and brazed it in place. After painting it looks just like the original.
Bob
sixt9x33rs
« Reply #2 on: September 17, 2010, 12:57:02 AM »
Bob
I am not that good...I will have to look for a junk one and press the nut out of a fender extension.
big iron
« Reply #3 on: September 18, 2010, 02:30:44 AM »
The inner front bumper extension is only $16.00 from Classic Ind.
Bob
sixt9x33rs
« Reply #4 on: September 18, 2010, 01:59:36 PM »
ok thanks
copo
« Reply #5 on: September 20, 2010, 06:51:54 PM »
I have a used spare from a old fender extension if you are interested in it.
sixt9x33rs
« Reply #6 on: September 22, 2010, 10:40:23 AM »
yes that would be great. My email is lmshaw@bellsouth.net or pm me.
Thank you
MyRed67
  • SZZLN 67
« Reply #7 on: October 06, 2010, 03:28:11 AM »
I have found that most of the Repops. don't have the correct nut attached.  They are usually a hex nut.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
« Reply #8 on: October 06, 2010, 04:01:56 PM »
I don't think anyone makes a duplicate of the original "pierce-nut"; they were auto-fed into a punch press, which had a die set that pierced the hole, inserted the nut, and peened the corners to retain it in the panel in the stamping plant. We hated them in production - if you cross-threaded the bolt, it would spin the nut out of the hole, and you had to repair it with a loose hex nut.
