Author Topic: Date correct alternator for 12C '68 L34  (Read 8180 times)
My68SS
« on: September 14, 2010, 08:50:55 AM »
Hi all, would a 37A 1100794 alternator date stamped 7L30 be about date correct for a 12c '68 L34 w/o ac with an engine cast of 7K30 and engine build of 1204?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
Re: Date correct alternator for 12C '68 L34
« Reply #1 on: September 15, 2010, 04:41:08 PM »
Yes, that date looks good.
My68SS
« Reply #2 on: September 15, 2010, 05:37:57 PM »
Thanks Kurt, :)
It's a re-buildable oneone I picked up of ebay to replace my obviously wrong one [date code, type, current, 2 groove L6 pulley - all incorrect] that came with the car.
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
My68SS
« Reply #3 on: September 15, 2010, 06:33:50 PM »
Actually, after reading this current carby thread http://www.camaros.org/forum/index.php?topic=7068.0 in the decoding board, I realised I wasn't calculating the dates quite correctly anyway.
I was assuming an alternator date that had to be slightly before the engine date.
This assumption was incorrect as the engine date is for only the bare long motor [minus carby, alt, dist etc.]
Whilst 7L30 is valid, it could have been anything up to about 7M8 or even later - i.e. after the engine date would also be valid [maybe more valid?]
In fact, depending on the exact time line between fisher body building, engine final assembly and chevrolet vehicle assembly, an alternator date that is in the same week as the fisher body date may also be possible.....
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #4 on: September 15, 2010, 07:03:13 PM »
Yup, that's true.
Except dist came with the engine...
My68SS
« Reply #5 on: September 16, 2010, 12:13:40 PM »
Opps, my bad. I guess that was fitted to block off the hole and prevent debris intrusion into the crank case?
Any idea what the typical time gap was between fisher tag build date and chevrolet commencement of assembly?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
stovebolt
  • 1968 L6 Sport Coupe
« Reply #6 on: September 16, 2010, 01:16:52 PM »
My68SS. That incorrect alternator you're replacing, would it happen to be an 1100813 dated no later than the first week of April 1968? Thanks, Joe.
My68SS
« Reply #7 on: September 16, 2010, 02:42:53 PM »
Unfortunately not, it's a 32A 1100720 8E21  :(
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #8 on: September 16, 2010, 03:12:57 PM »
The Fisher tag build date only indicated the WEEK the body started in the Body Shop, not the DAY; could have been any day of that week. It took a couple of days to go through the Fisher system before the body went to the Chevrolet side of the plant.
My68SS
« Reply #9 on: September 16, 2010, 03:34:34 PM »
Hi John, sorry, didn't word my question very well - yes, am aware it indicates week.
But your quote of 2 days for fisher is about what I was looking for.
The other bit is the time from fisher finish to chevrolet commence? - would it be same day for bodies that are out of fisher early enough during a day?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
« Reply #10 on: September 17, 2010, 01:41:08 AM »
Rob,
The timing is spelled out here: http://www.camaros.org/assemblyprocess.shtml
My68SS
« Reply #11 on: September 17, 2010, 07:25:21 AM »
Cheers Kurt,
Had read that report, though missed the bit in 'overview' where it quotes 2 days for fisher and 1.5 days for chevrolet [approx], with the entire process being virtually a non-stop line between the two plants.
It's a fascinating read, amazingly detailed! Thanks to John for compiling it!!   :)
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
