Author Topic: original water neck thermostat housing for a 1968 327 210 hp  (Read 9206 times)
malley67
« on: August 06, 2010, 05:35:25 AM »
hi guys,
just wondering what is the correct water neck / thermostat housing for a 1968 327 210 hp ? cast iron or aluminium ? and what is the correct thermostat 160 or 180 degrees ? i'm pretty sure its cast iron and 180 degrees but would like conformation.
thanks everyone,
cheers,
rohan
My68SS
Re: original water neck thermostat housing for a 1968 327 210 hp
« Reply #1 on: August 06, 2010, 02:07:47 PM »
alumin ium
Ah-ha, another aussie!  :)
According to PnA, 170f [180 is fine] and I'm pretty sure the housings were all aluminium - pn 3877660 seems to cover nearly all sb and bb 1st gen motors
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
rich69rs
  • LF7/M35/Z22/Z87
« Reply #2 on: August 09, 2010, 12:38:44 AM »
I would agree with the previous posts; although one year later - 69 327/210 used aluminum thermostat housing; cast iron are oftermarket replacements
I would assume the same to be true for 68.
Richard Thomas
1969 RS
« Reply #3 on: August 09, 2010, 05:26:35 AM »
alumin ium
It's probably easier to say than the way we say it.  I think the TH was cast.  I can't say just because of my Z28, but it was cast and the 69s were aluminum.
bowtie68iho
« Reply #4 on: November 05, 2010, 04:33:53 AM »
According to Group 1.153 in my “Camaro Master Parts Catalogue” (Dated July 1969) and “GM Parts History Index (Revised 1 Nov 1969),” Water Outlet 3877660 superseded 3896958 in July 1968.  According to the "GM Parts History Index," 3896958 (number on neck) was used between April 1967 and July 1968.  Both part numbers were aluminum.
68 NOR SS/RS L48/M35 Convertible
Cordovan Maroon - Special Paint Exterior (black stripes)
Black Custom Interior
Silver Concours (Legends Class) at 2012 Camaro Nationals, Gold Concours at 2014 MCACN.
68rs327conv
    • The build
« Reply #5 on: November 06, 2010, 12:36:22 AM »
I believe you want the 3877660, but with the part # on the base in 1968, not on the neck
68 RS Conv 327/210hp, Powerglide Factory AC
