Author Topic: 1969 8 track player location  (Read 9236 times)
Oaklyss
« on: July 30, 2010, 10:07:52 PM »
If a dealer were to install an 8 track player #91BT411 underdash unit, and there is a console in the car, were would it be installed? what bracket would be used? In the AIM it looks like U57 is installed under the ashtray, but that wont work with a console.
69 RSSS ZL-2 4 speed, mint unrestored 04A LA built-SOLD
1968 GTCS mint unrestored original paint
1972 AMX 401 4 speed, cowl induction, twin-grip, A/C, unrestored, original paint
1963 Oldsmobile Jetfire factory Turbo and Methanol injection, 4 speed, posi, 1 of 4 known to exist
Mark
Re: 1969 8 track player location
« Reply #1 on: July 30, 2010, 11:17:19 PM »
Dealer would install it anywhere it would fit, he not the factory and would have to make do.  Just pick a spot close to the console and screw it in.  Won't be easy to reach from the drivers seat though no matter where it goes.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
crobjones2
« Reply #2 on: July 31, 2010, 03:43:20 PM »
Based upon my car
it would have been installed under the radio and they would have cut the console for the unit to fit
Chris
69 SS 350
plumL78
« Reply #3 on: August 01, 2010, 01:38:16 AM »
Why wouldn't the dealer install the correct 8 track that mounted on the console in the first place
tom
    • Discount Internet Services
« Reply #4 on: August 03, 2010, 08:23:28 PM »
More profit on an aftermarket unit would be my first guess.
69 X11 Z21 L14 glide
o
lakeholme
  • 68-12D L30/M35
« Reply #5 on: August 04, 2010, 12:35:50 PM »
Chris,
Two questions:
1. Where did they cut it exactly?
2. How did they attach it.
tom
« Reply #6 on: August 04, 2010, 02:20:02 PM »
Chris, Please include photos if possible
o
Mark
« Reply #7 on: August 04, 2010, 03:42:13 PM »
Why would a dealer cut the console in a brand new car to fit a unit that would bolt under the passenger side dash panel just fine.  I know if i came to pick up my car and someone had hacked up my console the dealer would be putting a new one back in the car.  The dealer would probably install a motorola, or other aftermarket unit under the dash as close to the console as he could get.
If its not factory you don't have to worry about the "correct" way to install it, because there isn't one.  Dealer installed equipment is no differenat that previous owner installed hardware.  Get it as close as you can and go for it.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
crobjones2
« Reply #8 on: August 04, 2010, 05:43:57 PM »
directly under the radio - The radio is the AM/FM (not stereo)
Chris
69 SS 350
crobjones2
« Reply #9 on: August 04, 2010, 05:50:00 PM »
Let's say the dealer put the 8-track on the other side of the console - and now you have to reach over to change tracks while driving- not liikely
The 8- track was big- if you moved it over any closer to the wheel it would have gotten in the way of the gas pedal - the reason the factory decided it went to the rear of the console - when factory installed
Chris
69 SS 350
crobjones2
« Reply #10 on: August 04, 2010, 05:54:28 PM »
Chris,
Two questions:
1. Where did they cut it exactly? - see pic
2. How did they attach it. - the two screw holes under the radio held with some sort of bracket that the 8-track bolted to - I believe that determined the location and size of the cut in the console
Chris
69 SS 350
