Author Topic: 396 L34 water pump rebuild  (Read 7208 times)
My68SS
« on: July 27, 2010, 03:26:45 PM »
Hi crew,
Just in the process of rebuilding my water pump and just have a couple of q's for now.
Is the bearing pictured below the right one for '68 L34 - 3/4' shaft with 5/8' pilot?
Given the length of the front 3/4" section, it would seem that the fan hub presses nearly all the way on?
Does anyone know the hub's installed height dimension, from pump leg face to hub face?
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
My68SS
Re: 396 L34 water pump rebuild
« Reply #1 on: July 29, 2010, 02:01:21 PM »
Can someone confirm that this is an original impeller from a L34 water pump?
Cheers
Rob
1968 12C SS
L34/M40
12 bolt posi 3.55
big iron
« Reply #2 on: September 18, 2010, 03:28:45 AM »
Rob,
Good part number.
Bob
Cheers
