Author Topic: 69 DZ 302 19N62912  (Read 5296 times)
78MBA
69 DZ 302 19N62912
« on: July 23, 2010, 03:07:17 PM »
A completely rebuilt 1969 Z28 original DZ engine with orginal 1178 crank, pink rods, 186 heads, pistons, carb and intake. Stamping V0331DZ casting 3956618 4 bolt main with windage tray, N stamped on the main caps, O stamped on the rods Vin is ST along side oil filter, casting date C-26-9 original 3927172 STD bore pistons, 3927186 completely rebuilt and we have receipts for block rebuild. Heads with orginal pressed in studs, head casting dates 3-14-69 & 3-17-69, we have receipts. Cam is a new comp cam 30-30 replacement as recommended by Jerry MacNeish. Oil pan is not original to this engine. Heads & Intake have not yet been installed so that engine can be inspected prior to purchase. Also Vin stampin on block is 19N62912? Can't see the last Vin #. DZ carb was completely rebuilt & recoated.
Have additional pictures of the rest of the motor that can be sent upon request too many to post. $7500 OBO
If you have any questions call 804-241-2132
Re: 69 DZ 302 19N62912
« Reply #1 on: July 23, 2010, 04:07:49 PM »
Already posted with Ebay link...   http://camaros.org/forum/index.php?topic=3505.0
