Author Topic: D80 included???  (Read 30119 times)
mopar346
Re: D80 included???
« Reply #15 on: September 08, 2010, 12:35:53 AM »
Glad everyone is back. I actually finally looked this week end and it has the hole in the subframe. The picture above isn't showing anymore but I believe its the correct one. Did anything else come with the D80 option or just front and rear spoilers?
Re: D80 included???
« Reply #16 on: September 08, 2010, 02:40:46 PM »
Nope - just the spoilers.
mopar346
Re: D80 included???
« Reply #17 on: September 09, 2010, 02:33:29 AM »
Thanks, the picture came through tonight and it is the correct hole.
tryconcom
Re: D80 included???
« Reply #18 on: September 27, 2010, 04:35:22 AM »
When did  d80 become standard? and was it coded into the trim tag?
Gramps69Z
  • 69 X33 D80
Re: D80 included???
« Reply #19 on: September 27, 2010, 09:41:11 AM »
Spoilers (D80): The spoiler option was not available in 1967 on any Camaro. It became available as an option on all cars (except those with a rear antenna) in 68-69. It was not mandatory on any car, except for the 69 pace car replicas and later 69 Z's.
Per production options: CRG
Here's a picture of my tag with the D80.
Captain John Wykoff
L78 steve
Re: D80 included???
« Reply #20 on: September 27, 2010, 08:13:49 PM »
Is the bolt supposed to be pointing down as in the picture? Looks like a hazzard when sliding under on a creeper.
69 Z/28 Dover White. SOLD
Re: D80 included???
« Reply #21 on: September 28, 2010, 02:59:04 PM »
If you're asking about the center brace rod-to-subframe attachment, that's the way it was designed; see the Assembly Manual.
L78 steve
Re: D80 included???
« Reply #22 on: September 28, 2010, 08:06:47 PM »
I guess I need to turn mine around.
L78 steve
Re: D80 included???
« Reply #23 on: September 28, 2010, 08:08:41 PM »
Is that hole only on D80 cars? Or on all subframes?
Re: D80 included???
« Reply #24 on: September 28, 2010, 10:01:05 PM »
A subframe was not D80 prejudiced, none had the hole until the spoiler was mounted.
Re: D80 included???
« Reply #25 on: September 29, 2010, 04:03:47 PM »
The subframe hole was drilled using the brace rod as the drill fixture, as shown in the Assembly Manual.
L78 steve
Re: D80 included???
« Reply #26 on: September 30, 2010, 03:27:37 PM »
Had a look at mine. It does not have the 5/16 nut and bolt as shown in the pic. above. It has a 1/4 self tapping screw installed. Hole is to small for the 5/16 bolt. A variation?
jacmac
Re: D80 included???
« Reply #27 on: October 01, 2010, 01:20:22 AM »
 I notice your bolt drops in from the top & a nut is added.On my 69Z10 the subframe is treaded & the bolt just screws in to the frame to hold the spoiler bracket on??
<<Also look for a hole in the front subframe for the center support bar for the front spoiler. Someone here probably has a pic.>>
Here's a photo of the center support rod attachment to the subframe.
Gramps69Z
  • 69 X33 D80
Re: D80 included???
« Reply #28 on: October 01, 2010, 02:26:08 AM »
I doubt it's threaded, I bet it's a self tapping screw,
Captain John Wykoff
L78 steve
Re: D80 included???
« Reply #29 on: October 01, 2010, 12:22:28 PM »
As is mine.
