Author Topic: '67 camaro coupe, 327ci, 2B Carb., powerglide 2 SP  (Read 10851 times)
heckler
« on: July 20, 2010, 04:06:56 AM »
Carb. number in a circle on driver's side says....7013878
I assume it is Rochester as it has the raised letters....RP on top and side of carb.
What can I know about this carb.?
Re: '67 camaro coupe, 327ci, 2B Carb., powerglide 2 SP
« Reply #1 on: July 20, 2010, 02:20:48 PM »
That's a Rochester "Dual-Jet" 2-barrel, manufactured at the Chevrolet Bay City, Michigan plant. More info here:
http://www.camaros.org/carb.shtml
heckler
« Reply #2 on: July 21, 2010, 04:01:37 AM »
How can I find a model/part # without the tag usually mounted on front?
MyRed67
  • SZZLN 67
« Reply #3 on: August 07, 2010, 08:50:01 PM »
  I am dealing with this exact same situation, I will be watching this post closely!!  I'm pretty sure the carb. is correct for the car, I'm interested in rebuilding it, including finding somewhere to get a correct tag stamped.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
runuts
« Reply #4 on: August 08, 2010, 04:04:41 AM »
We have the same '67 combo 327, 2bbl, powerglide and smog with the original tag. I looked at the link regarding the carb tags and it's noted the tags were rectangular but mine is square. Were there two types? Was the gold color for the above combo? Sorry for the blurry photo, apparently phones are for talking.
MyRed67
  • SZZLN 67
« Reply #5 on: September 09, 2010, 03:12:21 AM »
Does anyone out there know where I might be able to get one of these triangle shaped tags reproduced?
1967 Camaro  LOS  11A
