Author Topic: Looking for owners with original early build '67 cars  (Read 7901 times)
MyRed67
  • SZZLN 67
« on: July 15, 2010, 10:24:55 PM »
  I am looking for some info. on an early build P. Steering Rag Joint.  I have a 11A (66) built standard V8 Coupe with the N40 Power Steering.  It has a ground wire between 2 of the studs 3/4 turn around with brass terminals on each end.  This would be top side (towards column), and should be viisable just looking down at the joint in the car.  I'm in process of restoration and would like to verify the authenticity of this joint.   If any of you could just take a quick peek, and reply, I'd much appreciate it.  Thanks!!!!!!     Mike
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
nuts4coke
Re: Looking for owners with original early build '67 cars
« Reply #1 on: July 22, 2010, 06:44:48 PM »
I have a 10C, almost all original, I will take a look, and maybe some pics, and see if that helps you out.
MyRed67
  • SZZLN 67
« Reply #2 on: July 22, 2010, 09:04:09 PM »
nuts4coke --Thanks!!!
1967 Camaro  LOS  11A
nuts4coke
« Reply #3 on: August 09, 2010, 11:53:48 PM »
Is this what you are looking for?
« Reply #4 on: August 10, 2010, 02:28:28 PM »
There were two versions of the rag joint ground strap - one was all brass, and the other was a wire with brass ring terminals on each end.
Mark
« Reply #5 on: August 10, 2010, 10:24:33 PM »
I just pulled the original rag joint out of my 69 04L Pacecar, it has the wire type ground connection on it.  Its not visible with the joint in the car, I didn't even know it was in there till I looked at the joint after it was out of the car.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
MyRed67
  • SZZLN 67
« Reply #6 on: September 09, 2010, 03:04:38 AM »
Mark, I'm like you, I didn't know it was there until it was out of car.  I'm looking at the pictures above, can't see it in the pics..  I was just assuming(I know the saying) that it would be visible, I just wasn't looking for anything like that.  Maybe there are a lot more out there than what owners realize.
1967 Camaro  LOS  11A
MyRed67
  • SZZLN 67
« Reply #7 on: September 16, 2010, 09:38:23 AM »
>nuts4coke; Thanks that's exactly what mine looked like before I took it out.  The ground wire is "tucked" in around the center of the rubber disc.  Goes 3/4 of the way around, probably really have to know what you're looking for.
1967 Camaro  LOS  11A
