Author Topic: 1969 Z/28 block casting numbers  (Read 21499 times)
x77-69z28
Re: 1969 Z/28 block casting numbers
« Reply #15 on: July 10, 2010, 03:57:56 PM »
my 05A car is the 010 block,
pdgarland
« Reply #16 on: August 06, 2010, 07:58:16 PM »
I have a 010 CE block, dated 11 69, with series # after it, and on the bottom, by the oil filter location, a date of K0215 . It had a # written on the side of the block in crayon of #3970647. A guy at the dealership told me it was replacement ' 69 Z fitted block, and that 397# was a service replacement # , ordered through the parts department. Sounds like someone turned a bearing, or worse, and had it replaced under warranty.
Looks like CE 9 5XXXX. It is a bare block though, no crank/rods or pistons, and no VIN. And NO, I don't want to sell it.
pdgarland
« Reply #17 on: August 06, 2010, 09:29:15 PM »
Ok, it has a code of T0218, it was a 8 instead of a 5, and has a K under it, all by the starter flange . So, it has a Tonawanda  CE code and date, but a  McKinnon foundry cast block, and K by the date also. Anyone seen anything like this? Did Tonawanda have a strike, and they use McKinnon cast blocks for warranty? Just curious. Never seen one like this... ever! It is a 4 bolt bare block.
CE 9 52xxx  on top pad
T0218   by starter
K
« Reply #18 on: August 07, 2010, 03:17:14 PM »
A "CE" replacement fitted block (block and pistons, no crank or rods) for a 302 wouldn't have come from Tonawanda; they didn't have the domed pistons in stock. Only Flint V-8 had domed pistons, solid-lifter cams, the 1178 crank, and the 2.02/1.60 big-valve head machining station with the intake valve unshrouding cutter in the cylinder head machining line. Tonawanda only built hydraulic-lifter 350's with flat-top pistons and 1.94/1.50 valves.
x77-69z28
« Reply #19 on: September 09, 2010, 04:13:57 PM »
my 05A z has the 010 block, i havent found anyone with an earlier vin with it.
