Author Topic: 68 camaro ignition switch  (Read 5278 times)
fireZ
« on: July 02, 2010, 12:18:55 AM »
How do you remove the ignition switch on a 68 camaro. All dash lights will come on with key but when I turn to start  the lights go off and starter does not turn over. Also the door buzzer works with the key removed with door open
1968 Z28 LA Built
LIC # RPO Z28
Re: 68 camaro ignition switch
« Reply #1 on: July 02, 2010, 03:43:16 PM »
Insert the key in the switch and turn it counter-clockwise as far as you can; then insert a bent-open paper clip in the little hole, push it in against spring pressure, and continue turning the key counter-clockwise. The key cylinder will then pop out, and you can remove the bezel, then the switch.
fireZ
« Reply #2 on: July 02, 2010, 03:48:57 PM »
Thanks John it worked easier than I thought
1968 Z28 LA Built
LIC # RPO Z28
